Don't bleed the clutch with a motive power bleeder.
Old Jul 19, 2010 | 12:25 PM
rcheung's Avatar
Although its awesome for the brakes, the motive power bleeder does not work with the clutch. My clutch petal went to the floor and would not come back up after I bled the cluch. I had to do it the manual way, push clutch down open bleeder screw, close bleeder screw, pull clutch back up with my hand. I had to do it about 5 times before the clutch started to feel springy again. Lesson learned.
Old Jul 19, 2010 | 12:45 PM
awd2gen's Avatar
I used one and had no issues.
Old Jul 19, 2010 | 01:57 PM
Evotech8's Avatar
You probably somehow got air in the line while doing the bleeding.
I always check the brake fluid reservoir is at max level before doing the clutch line.
Old Jul 19, 2010 | 01:59 PM
dyezak's Avatar
I did 2 clutches on NTEC's last mod day with a power bleeder...no problem.
Brokeassevo
Aug 31, 2016 09:23 PM
jimbo74
13
Aug 29, 2016 09:25 AM
jaycee842
11
May 27, 2016 06:35 AM
rob_d
27
May 2, 2016 09:23 PM
ak47po
Oct 21, 2009 09:52 AM
