Transmission overhaul
Old Jul 20, 2010 | 07:48 AM
wasenfutz's Avatar
So here goes I have a 95 JDM EVO III and the syncro is shot for 3rd gear. So i have ordered a syncro kit and rebuild set. I have a rebuild manual for my W5M33, and I have some experience with manual transmissions. So it should go fine, that being said, any input or tricks are welcome as this is the first time I've R&R'd on an EVO.
Old Jul 20, 2010 | 09:20 AM
lillev23's Avatar
Just follow the manual. Oh yeah. If you only had a bad synchro, reuse the same spacers that were in the transmission. No need to change them and mess up your clearances. To tight of a clearance will make the trans very difficult to shift.
Old Jul 20, 2010 | 11:35 AM
wasenfutz's Avatar
^ yes and thanks, the only real question is do I expect any problems dropping the tranny/transfercase out the bottom as one unit?
Old Jul 20, 2010 | 11:36 AM
wasenfutz's Avatar
Oh ya and I'm droppin in a centerforce clutch at the same time.
Old Jul 20, 2010 | 12:01 PM
rgar's Avatar
Getting the tc out of the way was pretty easy when I did my clutch.
The transmission was much more of a pain in the butt because of the amount of space(I didn't remove the subframe), but you can get it out.
agler2
Lancer Tranny/Drivetrain Tech
Mar 23, 2017 05:36 PM
TMajima
Dec 6, 2016 11:48 PM
moey124
Jul 14, 2015 01:36 AM
JRR
Nov 23, 2008 06:05 AM
EVIL_EVO_VIII
May 31, 2005 04:35 PM
