Oil Temperature & grade
Old Jul 24, 2010 | 09:17 PM
Esvees's Avatar
Hey guys,
Hope some of the more technically knowledgeable among you can help on this. I did an oil change a few months ago to Mobil 1 0W40 and it seemed to work ok.
But the weather has gotten much hotter now and compared to before, the oil temperature frequently hits over 100 degrees centigrade, even after just a little while of driving with boost. I want to take the car on the track, but am worried it'll get far too hot if I do.
A friend of mine who builds race cars said it shouldn't be a problem if the oil temperature stays under 130 degrees. Does this sound right?
Also, as far as I understand, the main problem with oil being too hot is it looses it's viscosity. if I use another grade like 10W50 or 10W60, would that be better for when the engine really heats up?
Thanks!
Old Jul 24, 2010 | 09:32 PM
dbased's Avatar
The temps stated sound pretty accurate. I always try and make sure my temps stay under 250f.
If you really want to learn about Oil grades and properties, I would recommend checking the forums at http://www.bobistheoilguy.com/forums/ubbthreads.php
There is WAY more information about motor oils there than any sane human needs to know.
Old Jul 24, 2010 | 11:35 PM
RSMike's Avatar
AFAIK the oil cooler "thermostat" doesn't open till 100C anyways, 130C oil temp should be ok with good oil. But yes, it's high. If the oil cooler can't shed enough temperature, it's going to pass the load onto the coolant system too.
Dmx3alo
May 26, 2017 11:06 AM
Luan Nguyen
Oct 30, 2016 03:26 PM
deza3000
Oct 4, 2015 11:09 PM
03_Lancer_ES
Lancer Engine Tech
Feb 11, 2008 11:23 PM
gen3eclipsegt
May 21, 2007 04:37 PM
