Got rid of my o2 sensor check light finally....
Old Jul 17, 2010 | 05:10 AM
silver fly's Avatar
i know some of us, who are using test pipes, were lucky enough to, not even throw one....but after the few years of using the black electrical tape cover and trying and getting frustrated with all the different parts......i decided to go back under the car and remove my o2 sensor from the vibrant extender sleeve.....looked at it really well and decided to clean it with brake clean.....now to think of what would deter it from lighting up again.....
in conjunction with the vibrant extender......mine was still throwing the code....
my solution:
kept the extender in place to avoid line of exhaust path.....but i wrapped the tip of the o2 sensor with 2 plys of aluminum foil.....poked a few holes that line up with the sensor so it can breathe and sense something.....it's working flawlessly.....for over 200 miles!......all this time i should have done this.....two years of looking down at the dash....how annoying.....
as a permanent fix....i am going to sleeve it with an aluminum cylinder sleeve and drill a few holes to breathe....maybe mess with some metal screen door material.....
hope this helps everyone else with this problem.....
Old Jul 17, 2010 | 08:37 AM
Craig King's Avatar
I could be wrong, but couldn't you simply take it to a tuner and have them reprogram the car to not detect the o2 sensor?
Old Jul 17, 2010 | 10:04 AM
fabcas311's Avatar
^+1
Old Jul 17, 2010 | 10:33 AM
silver fly's Avatar
i did try that.....i have a 2006 tuned by sean ivey....when i left it was cleared....but a days later popped back up.....so i tried everything and finally gave up.....this seems to be the only thing that has worked.....
aluminum foil wrapped o2 with tiny holes poked through.... installed in the vibrant extender
Old Jul 17, 2010 | 11:20 AM
fabcas311's Avatar
did u try packing some brillo/ss wool??it worked on my other cars...but i dont know if works in the evo. im gonna try it later on.
Old Jul 17, 2010 | 12:17 PM
silver fly's Avatar
well i thought about the steel wool, but realized that it rusts very fast and breaks apart when moisture is on it.....esp. if heated.....i decided on aluminum foil cause it withstood 450 degrees in my oven reapeatedly.....
Old Jul 21, 2010 | 09:58 AM
silver fly's Avatar
just letting everyone know that it's 650 miles later and still the light has remained OFF ....... ....what are you all waiting for?....lol
Old Jul 21, 2010 | 10:33 AM
rsboy's Avatar
The 2 anti-fouler trick has worked for me for over 30K miles. If I get the CEL, I just clean the O2 sensor and antifoulers a bit and it's good to go.
Old Jul 23, 2010 | 03:49 PM
silver fly's Avatar
curious.....what is that trick?
please elaborate
Old Jul 23, 2010 | 03:56 PM
ev0lution9's Avatar
i have 1 anti fouler on there and it works like a charm. some exhausts wont allow for 2 anti foulers because there isn't enough room.
Old Jul 23, 2010 | 04:16 PM
Evoryder's Avatar
V7 has an option to disable the rear o2.....no CEL.
Might want to check into that versus using baking foil.
Old Jul 25, 2010 | 09:15 AM
rsboy's Avatar
https://www.evolutionm.net/forums/ev...al-o2-fix.html
search for more info, cause it's been around for awhile.
please elaborate
rjsdxm
Jan 27, 2015 07:57 PM
project_lancer
47
May 19, 2013 03:18 AM
cdmassee
Oct 31, 2012 11:03 AM
mikane24
17
Oct 12, 2012 06:24 PM
djevoawhp
30
Jul 19, 2010 07:49 AM
