Yellow grease next to both axles.
Old Jul 26, 2010 | 06:00 PM
dvd_mi's Avatar
Hi everybody!!!
Two days ago a I changed the clutch on my 05 EVO. Clutch works fine but I noticed some kind of yellow grease spitted all over the area where axles connects to the tranny. It doesn't look like it going out directly from those axle-tranny connections, but it is coming out from somewhere. It is like that on both, driver and passenger axles. I don't see any leaks when I open the hood and rev, so it is probably happening while driving. Anybody knows what is going on??? Here are some pics of driver side.
Attached Thumbnails Yellow grease next to both axles.-sam_4292.jpg   Yellow grease next to both axles.-sam_4297.jpg
Old Jul 26, 2010 | 09:50 PM
dvd_mi's Avatar
bump
Old Jul 26, 2010 | 11:22 PM
MasterNater's Avatar
That looks like the grease from inside the cv joint. I would make sure the boots are not ripped on the axle. It seems unlikely that both boots would rip, but maybe you accidentally ripped them when you removed the axles.
Old Jul 26, 2010 | 11:40 PM
Roberti22's Avatar
yeah id inspect your axle boots for leaks thats what it looks like to me
Old Jul 27, 2010 | 04:33 AM
dvd_mi's Avatar
I thought that grease they use in cv joint is black.
Old Jul 27, 2010 | 09:06 AM
barneyb's Avatar
I've seen black, blue and yellow grease in axles. If it is grease, not oil, then that is the only source there. However, it should be easy to trace grease to its source.
I recently had to replace both inner boots on my WRX. No holes, they were leaking right through the bands. The replacement boots I installed show no sign of grease after two months of driving. So, dunno, maybe a crummy build at the factory.
MitsuJoe
468
Feb 20, 2016 11:17 AM
halfnhalf83
31
Oct 7, 2015 08:23 PM
volkevo9
Oct 22, 2011 07:36 PM
neonglh
Jun 28, 2009 11:27 AM
MitsuJoe
Aug 1, 2004 01:59 PM
