Still being battled by the boost monsters
Old Jul 28, 2010 | 07:58 AM
Tims2006MR's Avatar
I had a post about this before but it has changed a little..... In 1st-5th it holds at 15psi but in 6th it holds at 19psi. I just got a mbc but wanted to see if i could figure this out first so i dont mess anything up. Thanks in advance
Old Jul 28, 2010 | 11:01 AM
TeStUdO's Avatar
6th gear=higher load on the engine, which in turn, means higher boost.
Old Jul 28, 2010 | 11:18 AM
Tims2006MR's Avatar
i understand that but what i don not understand is why if stock boost is about 19lbs why im getting 4lbs less....
Old Jul 28, 2010 | 11:21 AM
XxApollynxX's Avatar
Did you do a boostleak test? Like Testudio said higher gear = higher load more boost. Did you install your MBC already or are you running just off wastegate?
Old Jul 28, 2010 | 12:06 PM
Tims2006MR's Avatar
yes i did a leak test, im still running off the stock boost control solenoid. I have not installed the mbc yet
Old Jul 28, 2010 | 09:00 PM
sparky's Avatar
If you stilll have your stock DV on hand then reinstall it as the Greddy BOV may be affecting the scene. Oh yeah, and get a retune while you are at it.
Old Jul 29, 2010 | 07:00 AM
Tims2006MR's Avatar
i bought it like that so i do not have the stock dv. Im going to go over everything once more i guess then put my mbc on and go from their
