Huge lag...4 month and no solution! help!
Old Aug 5, 2010 | 09:16 AM
evo8john's Avatar
could it be an issue with them not switching over the usdm map sensor to the jdm motor? that would cause a discrepancy in the load he was referring to correct?
Old Aug 5, 2010 | 09:42 AM
JDMevoBOOST's Avatar
Take a picture of the engine bay and we can help you.
Old Aug 5, 2010 | 09:51 AM
vmrevo9's Avatar
Veteran: Air Force
not sure what this would cause but its definitely a good thing to check
Old Aug 5, 2010 | 11:31 AM
andrewzaragoza's Avatar
what are you using for boost control?
Old Aug 5, 2010 | 09:19 PM
wase3's Avatar
i have an EBC and as per my tuner its working just fine. As for the discrepancy btw load and boost figuers, this problem is no more after the intake manifold was flushed. will post a photo as soon as i come back from work! again and again thanks a million for all of u
Old Aug 6, 2010 | 01:49 AM
project_skyline's Avatar
Originally Posted by Fast_Freddie
If it was a JDM motor that would have all the anti-lag equipment installed, if all that stuff was reinstalled onto an evo that isn't originally equipped that could seriously cause problems... need more information...
Thats an idea if it has all that stuff.
If its just a bare motor then wouldn't matter.
If boost is simply stuck on 15 psi it could well be a boost issue but if it tries to go higher but can't then it could be leaks.
Old Aug 6, 2010 | 01:18 PM
COL Knock's Avatar
With no boost considering:
1) Charge leak checks good from compressor to TB
2) No leaks in TB, intake or near injectors
3) WGA has a decent load and doesnt leak
4) No leaks from exhaust valve to turbo (even EGR)
5) The turbine housing is compatible with the turbine
Then you might have a leaking valve. You can rule this out quickly with a compression test.
Old Aug 7, 2010 | 02:30 AM
wase3's Avatar
[img]
Old Aug 7, 2010 | 03:42 AM
wase3's Avatar
these are the pics, the EGR as u can see in the 2nd photo is blocked bcs it's not compatible to my us spec car.
Old Aug 7, 2010 | 09:16 AM
cmj's Avatar
cmj
Looks like Fast_Fredie called it. Might be that antilag hardware causing the problem.
Old Aug 8, 2010 | 03:58 PM
wase3's Avatar
have u seen in the pics any antilag hardware?? if yes, pls point them to me bcs i have no clue about how they look like. thanks
Old Aug 8, 2010 | 06:59 PM
94AWDcoupe's Avatar
the silver pipes on top of exhaust manifold. those are antilag pipes. only there is no antilag valve on the engine. I would assume these pipes were blocked off so there is no exhaust leak befor turbo. they are not egr pipes.
I am still with my theory. when you tried new stock turbo did it come with new actuator can? the cans often get bent during wrecks and or shipping. a bent can can hold wastegate valve open. this causes slow spool and limited boost.
a leaking blow off valve can cause similiar poor performance. but usually runs like complete crap as a/f goes way off. check for broken diaphram or vacuum hose with hole in it
rushi
Aug 11, 2014 09:47 AM
nzevo8
Jan 2, 2014 12:09 AM
blade3609
44
Nov 6, 2011 12:44 PM
Jim in Tucson
Nov 21, 2010 09:29 AM
One-4-One
Sep 27, 2010 12:55 PM
