What Recirculating BOV???
Old Aug 5, 2010 | 08:09 PM
RSMike's Avatar
Originally Posted by EriCS
LOL maybe I didnt explain myself right. The same vacuum line for the stock diverter valve is what I used for the new one. I believe thats is from the intake manifold. I will check now.......
and you're using the T piece so that the pipe from the intake manifold is then split into the A+B ports?
If so, maybe the pipe diameter is too small?
Old Aug 5, 2010 | 08:10 PM
EriCS's Avatar
Okay yea the vacuum source for the BOV is coming from the throttle body. Should I take it from the turbo outlet vacuum line?
Old Aug 5, 2010 | 08:19 PM
EriCS's Avatar
I am only using one port. I don't recall the directions stating to t the vacuum line and hit both ports? I only have two, the older designs have three.
Old Aug 5, 2010 | 08:20 PM
EriCS's Avatar
Should I plug the stock vacuum line as well after I change it to the turbo outlet?
Old Aug 5, 2010 | 08:35 PM
ToxicFab's Avatar
Well if its not being used you should deff plug it. I guess you could go off the turbo but I don't think its going to help ur compressor surge.
Old Aug 5, 2010 | 08:47 PM
savagejay1's Avatar
Do you have a MBC? If so you should try connecting that source to the turbo outlet if you haven't already.
Old Aug 5, 2010 | 08:53 PM
RSMike's Avatar
No.
The A+B ports should be plumbed to the intake manifold, after the throttle body. when you close the throttle, it will apply vacuum pressure to the BOV, make it operate faster.
If you put A+B ports to the turbo compressor outlet, it will operate incorrectly.
Try it if you dont believe me.
Yes A+B ports should be used together, this will create more pressure/vacuum on the internals to make it operate faster, and should eliminate your flutter problems
Let us know how you get on.
Old Aug 6, 2010 | 04:00 PM
EriCS's Avatar
Ok so I Tee'd of of the stock vacuum line and hit both ports. It has gotten much better just driving around town but there is still surge at partial throttle/boost on the highway. The hose I used to pigtail to both ports its slightly smaller than the stock line so I am gonna try to buy a larger one to see if that helps but I doubt it. Big improvement though but still surging which makes me wonder how much damage this might be causing on the turbo. If all else fails TIAL....
Old Aug 7, 2010 | 08:52 AM
EriCS's Avatar
Update, so I changed the vacuum lines to the stock size to see if it would help but its still surging on the highway as soon as I accelerate or spool up on partial throttle then come off the throttle
I tried loosening the Nov but no better
Old Aug 7, 2010 | 10:27 AM
EriCS's Avatar
Old Aug 7, 2010 | 10:30 AM
boostedwrx's Avatar
I have the Synchronic and it's perfect. Just use one port A or B if your on the stock turbo and maybe even loosen up the adjustment rod a few turns. You actually want less pressure to be hitting the diaphragm of the bov and it will work better for the small peaky turbos like the stocker.
Old Aug 7, 2010 | 10:52 AM
ToxicFab's Avatar
Like i said before my post was deleted just use the port of the intake manifold. Should help.
GTisRule
Northwest Region
Apr 13, 2011 11:12 AM
evo4life400
16
Jul 16, 2010 06:23 AM
rob82
Apr 26, 2010 07:34 PM
Grendelrt
Jan 6, 2009 07:34 PM
GregV
Jun 21, 2001 10:30 AM
