Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Airfilter setup?
Old Apr 8, 2011 | 06:06 PM
GTisRule's Avatar
Airfilter setup?
Pretend I had a speed density sensor sitting in my front seat of my car atm, what setup for an air filter would I need? Since I get rid of the MAF, just a pipe to a cone filter thingy that I hate? Like 3" inlet?
Old Apr 8, 2011 | 06:08 PM
Jeff_Jeske's Avatar
Just a filter on the turbo would be fine. Ballers sometimes just use window screen and a hose clamp.
Old Apr 8, 2011 | 06:19 PM
RoninVIIIRS's Avatar
Yo Jason. Yeah, you pretty much just run a cone filter with an inlet the size of your intake. 7 inch filter is about right if you have the ACD reservoir. I recently picked up an amsoil air filter. They are light blue in color and just absolutely great quality. I don't think you can go wrong with an amsoil filter or a k&n cone filter for SD.
Old Apr 12, 2011 | 07:47 AM
GTisRule's Avatar
What size is the turbo inlet on a IX? 4"?
Old Apr 12, 2011 | 07:52 PM
JohnBradley's Avatar
2.5 more or less.
Old Apr 13, 2011 | 07:42 AM
GTisRule's Avatar
Dinky!
Old Apr 13, 2011 | 10:46 AM
D Grade's Avatar
True
But yes, if your intake is a 3" then you need a 3" ID cone filter. I have the ideal K&N filter at home and I can look up the model number for you. Its also a velocity stack style (open filtered end instead of closed end like most), which is something I prefer to run.
Keep this in mind, if you're running a short route UICP (ETS, etc...) you're gonna have some fitment issues with that MAF intake. I was running a Dejon Tool recirc'd MAF intake before I went to the ETS SR UICP. Upon install, I found that the UICP covers up about half of the intake opening. So with that in mind, you'll most likely need a non-MAF intake setup (something ER can make for you). Or you can make one yourself like I did.
Old Apr 13, 2011 | 11:12 AM
boostedwrx's Avatar
ER made me a nice SS intake with K&N filter when I was running the BBK turbo - it is same size as stock. Of course this was an SD setup but still worked and looked extremely well.
Braydo25
Lancer Aftermarket Forced Induction Tech
15
May 1, 2015 01:59 PM
FameEvo
10
Feb 13, 2015 12:40 PM
Englando
15
Sep 8, 2013 08:08 PM
Alfordz123
Sep 2, 2013 12:50 PM
mr.green
47
Apr 20, 2009 01:53 PM
