Knock and Boost
Old Aug 7, 2010 | 02:21 PM
keath's Avatar
Knock and Boost
So If your car is tuned on certain PSI. But you want it to run lower. so youturn the boost down with mbc.
Will this cause knock?
it is doing it on mine. tuned on 38psi but running 33 and it is knocking.
Will this make your car run rich? and cause knock?
E85 BTW
thanks
Old Aug 7, 2010 | 02:28 PM
4doorstreetbike's Avatar
E85 BTW
thanks
It depends how the car was tuned and aggressive the tune is what are your arf's now??and how much peak timing??
Old Aug 7, 2010 | 02:48 PM
keath's Avatar
AFR at full boost is around 11.7 to 12.3
22 for peak timing
Also making Tah Tah Tah noise from the exhaust around 5k-6k.
Old Aug 7, 2010 | 03:03 PM
22 for peak timing
and your getting knock with the boost turned down ????how much boost did you turn down too??also who tuned the car??
Old Aug 7, 2010 | 03:09 PM
keath's Avatar
turned down to 33.
knocks on 34 and the Tah Tah Tah sound from the exhaust.
Old Aug 7, 2010 | 03:11 PM
Evoryder's Avatar
Tah tah sound?
Should knock on lower boost. Only thing I can think of is the new load cells you're hitting. They may have too much timing.
Old Aug 7, 2010 | 03:12 PM
3gEclipseTurbo's Avatar
I thought e85 cant have knock?
Old Aug 7, 2010 | 03:16 PM
Originally Posted by Evoryder
Tah tah sound?
sounds right to me evoryder! ..E 85 is a very different then a pump gas or meth..
Old Aug 7, 2010 | 03:20 PM
keath's Avatar
Should knock on lower boost?
so i should ignore the sound and raise the boost?
Old Aug 7, 2010 | 03:37 PM
Heres an idea when you get your car tuned leave it the same after the tune. Why does everyon elike to change **** after they get a tune. No offense but you sound like my friend, he had gsx tuned at 29psi then decideds hes burning to much gas as he has to go wot every 2 min so he turns down the boost to 15psi, then turns down the fpr as he thinks his car is running rich then turns the boost back up to 20psi and turns his fpr up to more than it was when he was at 29psi. End story his car blew up as once you go changing **** its not tuned anymore!
Old Aug 7, 2010 | 03:44 PM
keath's Avatar
sorry
i was just switching map from 93 to e85
in the process of raising boost, this happened.
i just stopped at 33 instead of going back up to 38, because of the sound.
thanks
Old Aug 7, 2010 | 03:48 PM
bevolucion's Avatar
3geclipse is right, the only way I would have two boosts set up is if I was running two different maps for two different fuel. I really don't get the changing boost to safe gas, is all in the tune. I still get very good mpg in my 500hp+ capable car running 1000cc and round 27psi. And if you are running different fuel type then I would run an ebc like the aem, for accurate change in psi when you change maps.
edit: changing 93-> e85 know it make sense, + e85 to 93 oct definetly need two different tunes.
Old Aug 7, 2010 | 03:53 PM
keath's Avatar
Ok.
since i am on MBC with 2 maps with 2different fuel, solution would be for me to get EBC.
got it. thanks
Old Aug 7, 2010 | 04:01 PM
bevolucion's Avatar
in my opinion yes, for accurate boost. Just make sure that the ebc you run can be switched to two different boost settings, the aem does. you cans set . such as A:38 B:33 and you can switch boost whenever.
Old Aug 7, 2010 | 04:09 PM
Thats what I would do. And get a fresh tune.
