Boost Leaking ?
Old Aug 8, 2010 | 01:42 PM
Javo_EVOVIII's Avatar
Boost Leaking ?
Hi,
I install an Evo9 Turbo in my Evo8.
I can't boost more than 22psi, I tryed disconnecting the wastegate actuator and it's the same ( I suppose that disconnecting it i would hit 30 psi ) , but there's never going up.
I thought I was leaking in the pressure lines, couples. I look all connections and they look all ok.
Any idea ?
Thank's
Old Aug 8, 2010 | 01:49 PM
Sinbig's Avatar
You have to pressurize the system to find leaks. Search up boost leak test and it will show you the steps to do so. You are using a boost controller right?
Old Aug 8, 2010 | 02:01 PM
Yes, I'm using a boost controller.
The car first is boosting 19 psi. Next I start boosting 20.. 21 ...22 , and there's never going up. I disconnect the line of the wastegate actuator to look if charge more boost but it's the same. I can't boost more than 22.
I think there's a leak very important ( losing about 8 psi ).
I check all connections and they look fine. I don't know what's allowing to lose too much boost.
Old Aug 8, 2010 | 03:29 PM
Does anyone haved the same problem ?
Old Aug 9, 2010 | 12:34 AM
4g63Moon's Avatar
don't tell me your still using ur 8 bov..
Old Aug 9, 2010 | 01:21 AM
Evoryder's Avatar
Boost leak test.
Ted B
148
Jun 5, 2025 01:24 PM
WW14
Apr 3, 2017 04:48 PM
mines5
10
Mar 21, 2017 06:30 AM
Damian8MR
May 20, 2016 04:29 PM
EVOII
10
Feb 25, 2016 11:09 AM
