newbie question
Old Nov 21, 2003 | 06:54 PM
evo4.5's Avatar
newbie question
1 bar = how many psi?
wat i need to change in order to boost safely to 1.8bar?
wat is the maximum boost for stock internal?
Old Nov 21, 2003 | 07:02 PM
Quickshift's Avatar
14.5 psi = 1 bar
Rest I dunno for sure
Old Nov 21, 2003 | 07:05 PM
1QWKEVO's Avatar
14.5~14.7psi
i wouldn't go past 21-22psi on stock internals.... head bolts i believe start to give... the bottom end is pretty much forged so it's fairly strong...
May I ask why you want to boost 1.8 bar? If it's only for bragging rights then your picking the wrong reason.... Your concern should be more towards HP goals and if they are possible with what you have.... Boost isn't everything it's only 1 factor on a list...
1.8 bar= 26psi
why on earth do u wanna run that much boost? Stock turbo isn't going to fit your wants, you will def need a turbo, full exhaust, manifold, hardpipes, bov (racing app.) filter, injectors, fuel pump, fuel managment, boost controller, high octane fuel, headbolts if not internal work, and most importantly lots of tuning....
Hope I answer your question for the most part
Old Nov 21, 2003 | 07:10 PM
Compjoc's Avatar
I know you shouldn't push over 25psi (1.7 bar) on a stock evo 8.
Do you have a evo 4? I'm pretty sure with any evo engine you would need a built engine, big turbo, and all the basic bolt-ons (intercooler, IC piping, 3" turboback, fuel system, etc...)
Old Nov 24, 2003 | 07:39 PM
evo4.5's Avatar
thanks for the reply
i have another question,how much psi can a stock turbo withstand?
thanks
EvoAznBoi
Northeast Region
Nov 23, 2012 10:35 AM
hahnsolo
Jul 1, 2010 09:31 PM
Dingo7
Mar 9, 2006 11:37 AM
CweSt eVo
Apr 1, 2004 10:10 AM
createacat1
Oct 24, 2003 05:26 PM
