engine and turbo problems
Old Aug 19, 2010 | 03:41 PM
Spanishevo's Avatar
Question engine and turbo problems
i just put my fp white turbo on today and when i turn the car on it makes a wierd noise the turbo sounds like it has something stuck in it and the engine is making a rattling noise also wen i rev the engine past 3k rpms it sounds like the engine is skipping and idk wut to do ima take the turbo off and check it but i just got it back from forced performance completely rebuilt and all the engine internals are maybe a year and a half old so i was wondering if u guys had any suggestions that would be a great help to me also wen i cranked it the rpms were really low and it seemed like the car wanted to die out on me
Old Aug 19, 2010 | 03:45 PM
RSMike's Avatar
leak check all your intercooler piping and your AFM to turbo piping.
Old Aug 19, 2010 | 04:16 PM
EvolutinIX's Avatar
+1 boost leak test would help, did it have this problem prior to the turbo install?
Spanishevo's Avatar
thanks i will check it out but would that make the turbo rattle? and make the engine skip?
Old Aug 19, 2010 | 04:21 PM
Spanishevo's Avatar
before i took the turbo off and sent it to get rebuilt the car was running fine
Old Aug 19, 2010 | 04:23 PM
EvolutinIX's Avatar
If it didn't do it before the install it may be something very simple like a loose bolt. Can you post up a video so we can hear what your talking about?
Old Aug 19, 2010 | 04:28 PM
Spanishevo's Avatar
i cant take a vid right now but it sounds like something inside the turbo is rattling but i made sure everything was right but i was working on it all day out in the hot sun and got bit a million times by mosquitos so mayb that distracted me a bit but imma take the turbo off as soon as i can and check everything again
Old Aug 19, 2010 | 05:06 PM
06RedRalli's Avatar
Did u prime the Turbo prior to starting the car for the first time after the Turbo install?
Old Aug 19, 2010 | 06:42 PM
Spanishevo's Avatar
how do u prime it?
Old Aug 19, 2010 | 07:10 PM
sho669's Avatar
You pour oil in the centersection to prelube the shaft, I disable the IGN and crank untill I have oil press before starting, old habit.
Old Aug 22, 2010 | 06:07 PM
Spanishevo's Avatar
oh yea i did that i just didnt know it ws called priming it and i still havent got a chance to work on it ive been working all day every day these past couple of days
Old Aug 22, 2010 | 10:10 PM
EvolutinIX's Avatar
You did do this? I would double check over everything and if all looks well take it apart and start from sqare one, keep is updated. GL
Old Aug 23, 2010 | 03:44 AM
C6C6CH3vo's Avatar
Want me to drop by and see if I can find anything?
Old Aug 23, 2010 | 02:07 PM
20gmr's Avatar
there is a lot of stuff in that area than can rattle. Check the WGA and make sure there is tension on the flapper. could also be a heat shield.
Old Aug 24, 2010 | 04:11 AM
Spanishevo's Avatar
if u wanna drop by today man that would be awesome i was actualy gonna work on it today in the afternoon, i gotta go to school for a lab from 8 to 11 let me kno if u do want to come c it ill pm u my address
