OEM Head Gasket thickness?
Anybody know?...I just got my long block and head back from the machine shop for the second time after one of the JE wristpins snapped...the piston bent one valve I had it replaced and the head surface was machined. The guy at the machine shop told me to run a thicker gasket to increase the piston to valve clearance, the problem is I have not found the thickness of the stock one anywhere and I looked all over...
It's something like .053 but don't quote me on that, but you're not really going to find anything much thicker. At least, I didn't when I was looking. How much did the machinist have to take off?
EDIT: I'm finding everything from .050" to .060" when I try to find numbers, but most of them say these gaskets don't compress.
https://www.evolutionm.net/forums/ev...eadgasket.html
no more guessing.
measure by me, on the kitchen table
i ended up using the Evo9 HG because i'm running an evo9 head and wanted a slightly thicker HG for lower compression.
Cheers, Mike
no more guessing.
Cheers, Mike
STM Tuned
10
May 16, 2014 03:24 PM
DIDYSIS
18
Feb 24, 2013 10:14 AM
robotech
May 16, 2012 11:18 AM
compression, evo, evolution, factory, gasket, head, headgasket, layer, mitsubishi, mitsubushi, mls, mr, oem, stock, thickness
