Engine ticking sound help...
Old Aug 28, 2010 | 02:11 PM
Street gear's Avatar
Give me you opinion as to what my ticking is? I have put in new upgraded lifter but as you can see it still ticks. The strange thing is it goes away for a bit on startup and then starts. Please see video and give me your thougts.
Just to let all know this started after a WOT pull onto the freeway...
http://www.youtube.com/watch?v=H4iT0a3aQ7o
Old Aug 28, 2010 | 02:15 PM
Not4Sale's Avatar
sounds like your spark plug or your COP has a break in it and its shorting out somewhere. Does the motor idle and run good or does it run like crap?
Old Aug 28, 2010 | 02:20 PM
It idles ok as you can see from the video. I had a problem with the cop at one time it just misses but no ticking. I thought maybe it is a rod issue but if that is the case why would it go away on startup. It almost seems the lifters are not getting oil but when I remove the valve cover oil sprays everywhere. That shows there is oil pressure at least.
Old Aug 28, 2010 | 02:55 PM
javicracer's Avatar
i will put $$$ on a rod knock, drop the oil pan and check your rods!
Old Aug 28, 2010 | 03:01 PM
Do you think it is a spun bearing as it idles for a bit without making any sound. Has anyone ever seen a rod bolt go loose?
Old Aug 28, 2010 | 03:31 PM
Acree's Avatar
Seriously, check your rods. I had this same sound one night after a WOT pull. The next day, the rod pulled the wrist pin out of the piston and decided to leave out of both sides of the block.
-Acree
Old Aug 28, 2010 | 03:45 PM
4doorstreetbike's Avatar
Sounds like two things could be possible my man:
A.)The cop is missing spark and causing it to sound like popcorn
b.)Might be the lifters need to be bleeded or one has failed causing it to be sticking...
Its not a rod bolt or a bearing..I suggest to see if you have a stock igniton coils or find someone who does to start eliminating things first off.The next thing to do is pull the valve cover off and inspect for any damage or if see if something came loose.My money is on one of the coils went bad happened to my audi s4 the same thing was ripping it wot on the freeway came off and pulled to the light and sounded just like this but mine faded away in about 1 hour..How long has it been sounding like this???
Old Aug 28, 2010 | 03:46 PM
Pal215's Avatar
I'd put my money on rod knock.
Old Aug 28, 2010 | 03:49 PM
Still_Spinnin's Avatar
+1 Rod knock ticking time bomb fix that ****
Old Aug 28, 2010 | 03:54 PM
Yes..
Old Aug 28, 2010 | 03:58 PM
MRolla's Avatar
Sound like a rod bearing. Pull the oil pan and check for metal shavings in the pan. Fix this before you but a hole in the block.
Old Aug 28, 2010 | 03:59 PM
And STOP starting it! Your just making it worse lol
ddb's Avatar
ddb
Unplug the sparks plugs one at the time and ear what happens, if the sound totally disapear then probably a bad cop but if it still do it a little fainter then it is down below.
Old Aug 29, 2010 | 01:26 AM
Not4Sale's Avatar
I only said cop because mines had the same problem. It wasn't ticking that loud but I had to replace all of them. Except my car would shut off at random times and the bad COP was blowing my ignition fuse because of a short somewhere.
Old Aug 29, 2010 | 06:10 PM
dgrumpys's Avatar
man.... get a long screwdriver and poke aroudn the engine to find location of that noise. top or bottom end. then go from there. good luck
