Got a weird problem with tranny..need some advice.
Old Aug 29, 2010 | 10:36 PM
05VIII's Avatar
Recently I noticed that when I'm standing still, push down clutch and put it in first my car jerks forward a little bit while I'm still holding down the clutch. It doesn't start rolling or anything like that but it jerks forward a few inches.Do I need to adjust the clutch pedal or what? I bled the system 2 months ago If that makes any difference. What would you guys recommend I do?
Forgot to mention that after I hold down the clutch the first time I can pull it out of gear and put it back to first without the jerking. But if I release the clutch then push it back in and try first gear it will jerk. So basically it jerks forward 1 time after the clutch is pushed in everytime.
Old Aug 30, 2010 | 10:55 PM
konstantinosIX's Avatar
Had the same problem last week with my triple AMS.
Got an overhaul kit and all is OK now!.
Old Aug 31, 2010 | 08:09 AM
05VIII's Avatar
Anyone else experience this? Besides this, I have no other problems with my clutch. It feels strong and grips. It is 2 years old tho, holding up on a 35r. It's an act street clutch I believe. I guess I'll try adjusting the pedal, just not sure which way. Should I make the throw longer or shorter?
Old Aug 31, 2010 | 09:52 PM
05VIII's Avatar
well i adjusted the clutch rod clockwise and got rid of the "clutch hanging" but now the engagement point is really high. after 2-3 inches the clutch is open and got ALOT of traver after that. is there anything else i can do? if i turn the rod counter clock wise to have engagement further down will it cause the "clutch hanging" to come back?
Old Sep 1, 2010 | 05:01 PM
05VIII's Avatar
112 views and only one person makes an atempt to help? By the way kon, your post did nothing to help whatsoever.
Old Sep 2, 2010 | 01:51 PM
Try to push the clutch 1 inch before the end and get to the first gear.
Does your car jerks forward?
Old Sep 2, 2010 | 06:37 PM
outtanowhere's Avatar
clutch engagement should be closer to the floor than 1 inch in.
Old Sep 2, 2010 | 10:13 PM
05VIII's Avatar
Yea it did..I adjusted the rod clockwise and it doesn't do it anymore. Only problem is the engagement point is up so high now..after it engages I got A LOT of travel to the floor.
Guess it's time for a twin disk
