white smoke after wot
Old Aug 31, 2010 | 01:30 AM
mostafa911's Avatar
I have a evo 8 recently the oil dip stick has been popping out alot so i zip tied it down ever since then prob once a day after im in wot and i let off 2 seconds later a cloud of white smoke comes out of the exhaust.
i do have a stock turbo
i also have a check engine light for p0171 system to lean...
Please help
Old Aug 31, 2010 | 07:53 AM
4doorstreetbike's Avatar
Check to to see if your fuel pump is failing..Also check to see of the honey comb on your maf has been sucked in and try to clean it with maf spray when they get dirty from filters with high oil in them this code will appear.
Old Aug 31, 2010 | 08:14 AM
sparky's Avatar
Originally Posted by mostafa911
I have a evo 8 recently the oil dip stick has been popping out alot so i zip tied it down ever since then prob once a day after im in wot and i let off 2 seconds later a cloud of white smoke comes out of the exhaust pipe...
Could be the seals in the turbo taking a dump.
Old Aug 31, 2010 | 08:59 AM
turbolarry's Avatar
White smoke is coolant. It might need a new head gasket.
Old Aug 31, 2010 | 09:25 AM
Ev0ikon's Avatar
Your PCV needs cleaning/replacement.
Old Aug 31, 2010 | 09:33 AM
LanEvo9MR's Avatar
Originally Posted by turbolarry
white smoke is coolant. It might need a new head gasket.
+1
Old Aug 31, 2010 | 10:09 AM
mostafa911's Avatar
i did a compression test 180 across the bored
and after work today i will clean pcv and maf and see wat happens
Old Aug 31, 2010 | 01:18 PM
mostafa911's Avatar
ok so i disconected the intake to clean everything and the intake is litterally dripping oil wat is going on some advice please
Old Aug 31, 2010 | 01:31 PM
igo4bmx's Avatar
this is it.
during boost your pcv is not closing pushing boost through the pcv valve pressurizing the block
Old Aug 31, 2010 | 04:40 PM
mostafa911's Avatar
Changed pcv same problem
Old Aug 31, 2010 | 04:46 PM
Gary@MellonRacing's Avatar
the white smoke + a sweet smell coming out the exhaust = coolant
Old Aug 31, 2010 | 04:53 PM
evo unknown's Avatar
White smoke is evidence of a coolant leak, most likely from the head gasket. Burning coolant that is leaking will have sweet smell to it like syrup.
Old Aug 31, 2010 | 04:57 PM
mostafa911's Avatar
No sweet smell burnt oil smell nd intake filter is dripping oil
Old Aug 31, 2010 | 05:01 PM
buchnerj's Avatar
Could be seals on the turbo are going bad and you are letting oil and coolant into the charging system. As people stated before, white smoke means you are burning coolant somehow. Only ways to be doing this are a leaky head gasket or the turbo seals starting to go bad and leaking things into the IC pipes, etc. A leakdown test will confirm wether or not it is the head gasket, and I would check the turbine for shaft play to judge the wear on the turbo. Make sure to clean everything up after you figure out what it is, oil in the IC and pipes can get things inside the motor and valvetrain quite messy/
Old Aug 31, 2010 | 09:50 PM
mostafa911's Avatar
ok so i havent found anything out yet i did a boost leak test i boost leak tested from on the turbo not on intake nd after i started the car alot of white smoke came out from exhaust and oil was dripping from exhaust and i drove about 1 mile and i checked my oil level and there was no oil just a little drop on the end of dipstick what would cause all the oil in my engine to go out my exhaust guys i need help car was good a couple days ago now its all messed up someone help please
