This for for those that run E85. How often do you do change your oil?
Like the title says how often do you guys change your oil. I usually do mines around 3000 but I heard its not good to wait so long especially if you daily the car. Do you guys have any input on this
Why not just send in your oil after 3 - 5K intervals and see what the analysis tells you ?? I'm sure with a good oil that 5k mile intervals is more than fine (just a guess though) for a DD.
I changed mine roughly every 3k, sooner sometimes because of mod changes.
I did not do anything differently, I have heard recommendations to change it more often though, but take that with a grain of salt.
DD'ed my car for 26k miles, through rain, lots of snow too. Corn juice half those miles, 60 miles a day at least.
Would still be DDing it too if I had it running.
You really have to be careful with e85 as it is harder on oil than gasoline is. I do not daily drive my car so instead of changing at a milage interval i try to change every 2 months, or when my oil begins to have a faint alcohol smell to it.
there is no one who has tested the oil to build a baseline for their specific situation you cant use data from different cars to come to a conclusion for your specific case, i test my oil on E85 you cant use the data because your car might be very or slight different. although to be on the safe side use a high quality synthetic and drain at 3k would be plenty conservative
you need to get your own UOA and that will educate you on how often YOU can/need drain.
1200-1500 miles. From what I understand, E85 tends to ruin the oil sooner than normal unleaded 93 octane. 10w-30 (15w-50 in summer) Mobil 1 / K & N Filter used here. But then again...I am someone who will bend over backwards to keep my car in what I think is top shape.
RA2013
Jun 19, 2015 07:43 AM
