Pls Comment On My Set-Up...
Old Sep 18, 2010 | 10:27 AM
jameswwt's Avatar
HI,
pls kindly advise and share what is the ideal engine set-up as below is my current set-up :
(Target - Is to have great Throttle Response and minimum Lag)
1) Stock Evo 5 TD05HR 16G turbo
2) 600mm x 300mm x 70mm IC
3) 2.5" IC pipings
4) Stock Intake & 65mm TB
5) GSC S2 cams
6) Manifold with turbosmart wastegate
7) Stock 560cc injectors
If i port my intake manifold and TB to 70mm will it have better low end power or increase lag?
Boost : Low = 1.2bar / High = 1.4bar
Thanks
Attached Thumbnails Pls Comment On My Set-Up...-09042010208.jpg   Pls Comment On My Set-Up...-16122009032.jpg   Pls Comment On My Set-Up...-09012010053.jpg   Pls Comment On My Set-Up...-30032010193.jpg
Old Sep 18, 2010 | 10:54 AM
sparky's Avatar
Originally Posted by jameswwt
.... what is the ideal engine set-up as below is my current set-up....Manifold with turbosmart wastegate...
What manifold are you using in conjunction with the Turbosmart WG? Do you have the stock, integral gate welded shut?
Old Sep 18, 2010 | 10:56 AM
FedEvo8's Avatar
It would be wise to port the hotside and turbo manifold as well...What are you using to control boost?
Old Sep 18, 2010 | 11:55 AM
sparky's Avatar
Would you please share your current post-turbo exhaust setup with us. I am refering to the type of turbo elbow(O2 housing), downpipe, catalytic convertor/test pipe, cat-back exhaust.
Old Sep 19, 2010 | 03:38 AM
jameswwt's Avatar
Hi guys,
thanks for sharing and here are some of my engine set-up pictures.
Im using Greddy Pro-fec B II boost controller and a 3" straight pipe from the stock turbo downpipe.
Old Sep 19, 2010 | 05:27 PM
jameswwt's Avatar
Hi,anyone to share?
Old Sep 19, 2010 | 07:19 PM
sparky's Avatar
Upgrade the stock turbo to the new HKS GT7460 GTII ballbearing turbo. This is a direct replacement for the stock turbo. But, it should give you about 90 engine horsepower more than your existing stock turbo. Furthermore, it will spoolup just as fast as your stock unit. You will need larger injectors and a higher volume fuel pump.
Old Sep 19, 2010 | 07:39 PM
sparky's Avatar
Do the complete post turbo exhaust. Start with replacing the stock O2 elbow with an O2 dump. Get a full 3" diameter downpipe as well.
Old Sep 19, 2010 | 07:41 PM
sparky's Avatar
He has a tubular header already.
Old Sep 19, 2010 | 09:42 PM
jameswwt's Avatar
Thank you so much Sparky
Old Sep 20, 2010 | 05:15 AM
oreoevo's Avatar
Bump
Old Sep 20, 2010 | 09:41 AM
lttletimmy's Avatar
Your injectors and fuel pump (if you are on the stock one) are holding your setup back right now, I don't think porting the TB is a good idea now, that will hurt your low end more than help it.
Old Sep 20, 2010 | 10:11 AM
jameswwt's Avatar
Thanks guys,as im running a walbro 255 fp and yes,decided not to touch on the intake and tb....
evotris
Jan 2, 2013 10:01 PM
jameswwt
Aug 21, 2012 10:36 AM
jameswwt
43
May 4, 2011 06:25 AM
jameswwt
Oct 12, 2010 07:11 PM
woobos
For Sale - Cars For Sale
Jun 19, 2006 11:32 PM
