View Poll Results: Which 8 cams do you like for autocross/timeattack racing with Supertech dual springs?
GSC2 274
51.28%
Kelford 272
27.35%
Forced Performance 4R
0.85%
Cosworth M2
6.84%
Tomei 272
3.42%
HKS 280
2.56%
JUN 272
7.69%
Voters: 117. You may not vote on this poll
Which cams to go with? GSC2, Kelford, JUN, Tomei
Old Sep 20, 2010 | 07:22 AM
n2oiroc's Avatar
Originally Posted by ryukinevo
Do you have cam gears installed in case you want to adjust the powerband? I found that most do not use cam gears for fear of them braking. However, if you want to time attack or autocross; I wonder if it would be helpful so your not stuck with a certain powerband?
Your much better off asking a tuner. With gears you can move the powerband around but as far as the pro's vs. Cons im not sure.
Old Sep 20, 2010 | 08:28 AM
SmurfZilla's Avatar
What does everyone think of the new HKS cams?
Old Sep 20, 2010 | 09:02 AM
lttletimmy's Avatar
Have you considered cosworth M2s? They might not make the power of S2s but you can use the stock valvetrain if you don't go over redline. If you want added peace of mind with any cams, stiffer valve springs are cheap insurance.
Old Sep 20, 2010 | 09:18 AM
EVO(boss)'s Avatar
Hks 280
Old Sep 20, 2010 | 09:46 AM
68FBODY's Avatar
Gsc s2!
Old Sep 20, 2010 | 11:40 AM
ryukinevo's Avatar
It sounds like a lot of responded people like the GSC2s and Kelfords. I will take the BR 272s and JUN 272s off my list since I heard they were very similar and not good for autocrossing.
1 vote so far for the Forced Performance 4Rs.
I also heard the Cosworth M2s were good too.
I heard that HKS 280s were good too.
No mention of the Tomeis yet?
So far, I am still leaning towards the GSC2 274s with BR/ Supertech dual springs and titanium retainers. Also, AEM timing gears in case I need adjustments to the powerband. I do not want to feel stuck since I am not doing the install. I will keep checking the forum for further ideas.
Old Sep 20, 2010 | 03:00 PM
Teal2nnr's Avatar
I bought Kelfords.....so they have my vote (Set up a pole if you really want.....)
Old Sep 22, 2010 | 11:34 AM
bmxer4it's Avatar
I know multiple people with each of these cams. When looking for my cams... i took info from all of them, and also from many multiple knowledgable tuners/builders. Overall... S2's. All good cams.. but i see that the S2's outperfrom the others... hope this helps
Old Sep 22, 2010 | 11:48 AM
1NastyMR's Avatar
I suggest gsc s2's for what your looking to do with the car.
Old Sep 22, 2010 | 12:04 PM
lttletimmy's Avatar
If you're definitely upgrading your valve springs, I agree on S2s, which is what I voted for in the poll.
Old Sep 22, 2010 | 12:05 PM
Boosted Tuning's Avatar
Either GSC S2's or Kelford 272
Originally Posted by raulthode
Didn't see Brian Crower cams on your list: so far i've read that they are a great bang for the buck and their 272's do not require any further changes to the valve train.
You dont see anyone recommending BC cams because they are not that great.
Old Sep 22, 2010 | 04:33 PM
hokiruu's Avatar
Interesting question since you have a 35R and say you intend to autocross. A 35R is HUGE for autocross, and is far below its ideal efficiency at autocross speeds. The ideal cam for a 35R for TA vs. Autocross (35R just isn't ideal for autocross) could be very different. This could mean you may want a cam that will help counteract this, but that probably means you will lose some of the 35Rs potential up top. On a road course if you're staying at higher average speeds and RPM, you may be able to get away with a cam that takes a bit more advantage of upper end. I don't know which cam will be the best for both or either, but just food for thought while choosing. I was torn between the first 3 on your list and took what I got for a great deal. Your needs may be even more specific, so think about where you're going to be spending the most time and where you want them to benefit you the most.
Old Sep 22, 2010 | 05:07 PM
evo8 951's Avatar
I would go S2 for sure. I been hearing so much good things about them. I'm sold.
Old Sep 22, 2010 | 06:10 PM
ryukinevo's Avatar
I appreciate the information. I know that the GT35R might not be an ideal setup for autocross/timeattack racing even though I have seen a lot of cars running it. I got a great deal on it and I am going to use it until things change down the road. I know that the GT35R will give me plenty of power to do most any type of racing. I am installing the turbo kit myself, but I don't know how to install the timing belt and cams so this mode is more permanent for me since I will have to pay to install different cams later if I do not like them.
So far it looks like GSC2 274s and AEM timing gears (in case I need to adjust the powerband) get my vote!
I will keep checking this thread for more information until I decide and order my cams.
Thank you
Old Sep 22, 2010 | 07:35 PM
nightwalker's Avatar
I noticed you said you want auto-x type power and strong midrange, but you have a GT35r. Kind of backwards isn't it?
