View Poll Results: Which 8 cams do you like for autocross/timeattack racing with Supertech dual springs?
Voters: 117. You may not vote on this poll
Which cams to go with? GSC2, Kelford, JUN, Tomei
I'm curious what the duration numbers at 0.050" are on the GSC S2 cams.
Spec wise, they are using essentially the same lobe centerlines as the FP4R cams. Lift is almost the same between them as well. The duration is also very similar, but the GSCs are listed at 1mm instead of 0.050" so a direct comparison isn't possible.
GSC should be the only route you go. I gained 90hp, less boost, going from HKS 272/280 to my custom GSC 274s and didn't lose any spool. Tell why you would want to go with anything any different? You wouldn't, trust me...
Attachment 338718
Mikey
Attachment 338718
Mikey
This is good but the OP has an 03 not an Evo 9.
