View Poll Results: Which 8 cams do you like for autocross/timeattack racing with Supertech dual springs?
Voters: 117. You may not vote on this poll
Which cams to go with? GSC2, Kelford, JUN, Tomei
S2's just cannot be beat! FP makes great cams, but if you have an VIII and can find the Jun's they are def a great cam for TA, but with the new revised S2's it's hard to beat them for the money.
It would depend really on whether or not you want to swap your valves I would think. There's not tooo much of a selection out there that allow you to keep them stock. I personally like the HKS272s, they pack some pretty good power and allow you to keep stock valves/springs. Only issue I've run into is the cold start seems to have a low fuel pressure but goes away after like 3-5 seconds. Good luck
Thats because brian crower cams blow ***.
I'm curious what the duration numbers at 0.050" are on the GSC S2 cams.
Spec wise, they are using essentially the same lobe centerlines as the FP4R cams. Lift is almost the same between them as well. The duration is also very similar, but the GSCs are listed at 1mm instead of 0.050" so a direct comparison isn't possible.
the new s2's are 228 @ .050".
i got jun 272's w/ supertech dual valvespring setup aem cam gears..2.2 stroker ,stock head.fp black my spool is around 4300 4500k rpms.25psi e85.they do feel more of a mid range top end style cam.501whp on single pump 1200cc rc injectors 540 on q16 and im more into road racing setup and thats what i told the tuner.is i want a road race style tune redline is 7500rpms..not looking for max power.so i think i got a pretty good mid range setup...actually wouldnt mind hta green or red ....
