Low boost IX
Is the car bone stock? Check for boost leaks like everyone says. If you dont know how its done, then take it to a tuner shop that has an air compressor that can do the test for you.
Since the car was purchased used, then previous owner may have altered the stock boost control setup. Some guys have EBC's, or MBC's, or Ecu based boost control with altered BCS's or different pills installed and when they go to sell the car they don't completely put it back to a stock fuctioning boost management.
boost check first. its cheap and easy.
but then again, when i boughtmy first evo, it was only boosting 15psi, turns out one of the wire on the MAF where cut, have not clue how but fixed it and was back to 20.
It is posible it had a mbc in it at one time it looks like it had a different intercooler also but now is stock. thanks for the info im going to get it tuned but want to do s2's, black and meth over winter so im not going to waste the money to tune it now.
When I first bought my Evo it had a MBC and was hitting 21 psi. There is no shaft play on the turbo and no boost leaks. I removed the MBC and reinstalled the BCS (because of my autox class) with the factory vacuum line with both stock pills and correctly routed. Now it only hits 15-16psi and tapers to about 14. We tried my buddies Evo 9 bcs which is know to work and there was no effect. The boost settings on the tune are 100% stock.
I have been trying to figure out why I am boosting 4-5psi low. This could be one possibility but which wire would cause this and is there a way to test it with a multimeter to make sure everything is electrically sound on the MAF and BCS?
When a lotta of these cars are "returned" to stock to be sold, they dont put the OEM boost system back correctly and it will boost wastegate pressure, ie 11-14psi.
OP, I would recommend first doing a boost leak test. If it turns out ok, then I would pick what form of boost control you'd like to use (either MBC or 3port w/ ECU Boost), then go buy it and use it.
This.
