Low boost IX
Old Oct 12, 2013 | 09:15 AM
  #46
sparky's Avatar
Originally Posted by evohmoob
......3rd and 4th gear do boost up to 1.4 bar, but if you start from 1st they stay close to 1.1bar all gears then tapers down
On a mechanically supercharged engine, the supercharger's shaft speeds are directly proportional to engine RPM's. Thus, in a supercharged engine, " x" bar of manifold pressure will be achieved at the same motor RPM regardless of what transmission gear is engaged. This direct proportionality is due to the fact that the supercharger's shaft rotation is driven off the engine's crankshaft, or camshaft or other directly driven puley or gear. So, for example, if 10# boost is reached at 4000 motor RPM in 1st gear, then 10# will be attained likewise at 4000 RPM in all transmission gears.
On an exhaust driven turbine, or turbocharged car there does not exist a directly proportional relationship between manifold boost pressure and engine RPM's across the range of transmission gears.
Do a WOT pull in 4th gear starting at 3000 RPM and tell me at what RPM you see 20#(roughly 1.4BAR).
Old Oct 16, 2013 | 01:48 PM
  #47
evohmoob's Avatar
around 4000rpm
Old Oct 18, 2013 | 03:35 AM
  #48
sparky's Avatar
So, 20# @ 4000 in 4th gear is way too slow, way too late on a stock IX turbo setup. Ideally, you should be seeing that boost level somewhere around 3400 RPM.
We can try troubleshooting the issue with the factory ECU/BCS system. However, you had mentioned that you were thinking of installing an MBC. I prefer the MBC over the stock setup for troubleshooting wastegate control issues, and relative ease of determining wastegate spring pressure.
Old Oct 24, 2013 | 01:11 PM
  #49
evohmoob's Avatar
well ive ordered a hallman pro MBC along with injen intercooler piping kit and oil catch can
WW14
Mar 13, 2017 02:29 AM
lanceresx9
Jan 10, 2017 06:49 PM
illogicalmind
Nov 16, 2014 05:56 AM
beasters
Oct 30, 2014 04:01 PM
LncrRA
20
Apr 12, 2013 10:19 PM
