Help tranny won't come off
Old Sep 26, 2010 | 07:46 PM
still*boostn's Avatar
Originally Posted by batty200
Make sure all the bolts are out! Otherwise it is a PITA sometime to get out. Good luck!
You cant be serious. lol
Originally Posted by Spoolin4g63
if its the TOB, i would just unbolt the flywheel from the motor and drop the tranny with the clutch and flywheel..! I went threw this with my buddys car..
I think you ment the pressure plate, but yeah thats what I had to do.
Old Sep 26, 2010 | 08:34 PM
batty200's Avatar
You would be sirprised how many times there is a bolt hiding somewhere that is still in. I just like to put it out there because if everyone tells you to go hard and you break something you will be pissed that a bolt was still in there. Glad you got it off apperently.
Old Sep 26, 2010 | 10:33 PM
Spoolin4g63's Avatar
yeah...whoops
Old Sep 27, 2010 | 04:30 AM
tscompusa2's Avatar
yeah...whoops
I was about to say LOL.. where did you get your alien powers from.
Old Aug 11, 2012 | 01:35 AM
4g63Evo8's Avatar
Having a problem with my tob right now. Can't get it to pop off the screwdriver will not pop it off the clip on the flywheel I tryed the guides and videos. push in fork pry screwdriver inbetween tob and and clip twist screwdriver(can't get it to turn at all seems stuck) pops off done. Can't get it to pop idk tryed for hours. Is it possible to get at it another way?
Old Aug 11, 2012 | 02:15 AM
Piro Fyre's Avatar
Yeah. Start unbolting the pressure plate from the flywheel. You can reach each bolt through the clutch fork hole. When you're done with one, rotate the crank and unbolt the other. Do until all 6 are out.
Old Aug 11, 2012 | 02:59 AM
jeffbeagley's Avatar
if its the TOB, i would just unbolt the pressure plate from the motor and drop the tranny with the clutch and pressure plate...! I went threw this with my buddys car..
Late Apex
Jul 17, 2016 03:43 PM
Viet-Speed
Apr 23, 2013 03:57 AM
mr.almeida
Apr 19, 2010 10:10 AM
Nastynine
Apr 10, 2010 05:45 AM
AlwaysinBoost
Sep 14, 2009 01:01 PM
