Help tranny won't come off
Old Sep 24, 2010 | 06:42 AM
birdhead's Avatar
Exclamation Help tranny won't come off
Ok here's the problem my tranny wont come off I fallowed the guide and called a friend I took the transfer case spindles out clip on clutch is out the trans is got a small gap but won't come out. Pls help if u are in the fallbrook ca area it would be greatly appreciated if u could help me
Old Sep 24, 2010 | 06:54 AM
BoostINurI's Avatar
Tob not disengaged don't f it up man or it will be hell getting trans off. I hope you got the tcase outta the way also. GL
Old Sep 24, 2010 | 07:01 AM
evoracingstar's Avatar
You took out the spline that goes in the transmission to the tcase on the drive side right? If not the tcase will only come out so far. Do u got it completely off the tcase? If so what u got to do is push the tranny upwords like spin it It will fall right out. If u dnt spin it up towards 1. 2 o'clock I will just be stuck on ur subframe gl!
Old Sep 24, 2010 | 08:12 AM
birdhead's Avatar
Yea the tob is out and loose we tried jacking the tranny ip then tried a strap nothing
Old Sep 24, 2010 | 08:25 AM
still*boostn's Avatar
Just double checking cuz i just dropped my motor back in my car last night so its all fresh.
Your 100% sure the throw out bearing is release?
You took out both splines?(out from each end where the axels go?)
And is your transfer case completely off the tranny?
If those three are yes', then is should come right off. Only thing i could think of if its jamming against the side of the car that your not seeing, or the tranny spline ir rusted to the clutch disc?(never heard of that happening but just a sudjection.)
Old Sep 24, 2010 | 11:30 AM
another thing your rear tranny mount makes it easy just taken it right off the tranny 3 bolts then the one bolt in the middle. give you more room to play with the tranny. u just got to keep going back n forth it can be a pain in the a$$ just did mine
Old Sep 25, 2010 | 10:02 AM
birdhead's Avatar
Ok I checked everything again last night the transcase is hanging and the tob is defiantly off it seem something is ****d up when I first bought my car from south coast Mitsubishi I was driving home on the 405 about 20 miles from the dealer and started to get in to boost and it was throwing it out of 5 th i think the dealer ****ed something up o and there is a 1/2 in gap in the front and a 1/6 in gap in the back we tried closing the front gap but it keeps coming back
Old Sep 25, 2010 | 10:14 AM
tscompusa2's Avatar
The wedge collar needs released from the TOB or the trans will not come out ever. If its released the clutch fork will rest all the way over to one side and stay there.. if your fork arm is not forced to one side like its disconnected, then its not disconnected.
If it is, and its still not moving its cause there are pins that the trans rests on that stick out of block and trans.. use a big breaker bar type flat head and wedge it off. wedge AFTER the gasket type piece inbetween the trans and block.. the gasket /metal plate is bolted to the block itself.. it does not come out with trans.
hope this helped. also you need to pull the spline gear from the transfer case out also, or the trans wont disconnect from the tcase.
Old Sep 25, 2010 | 08:48 PM
EVO8STI's Avatar
i know what your going thru man. took me 3 hours to get mine unwedged. gl
Old Sep 26, 2010 | 12:26 AM
Mr1mike2001's Avatar
Dude start back from about step one and make sure everything is disconnected, its time consuming but making sure everything is off and in its place would be where to start. After that I would suggest a crowbar.......to get mine off the first time I had to get up under the car I had a jack up under the tranny and wedge the bar in between the bellhousing and the motor and give it a few good jerks, it actually pulled it off just enough so that I could give it that little twist and get it on out. And I would defnitly suggest following evoracingstars advice on take that rear tranny mount out, That mother gets hung on the subframe coming out and even more so going back in its a PITA. Good luck bro
Old Sep 26, 2010 | 06:26 AM
batty200's Avatar
Make sure all the bolts are out! Otherwise it is a PITA sometime to get out. Good luck!
Old Sep 26, 2010 | 10:35 AM
INEVOIX's Avatar
Just in case you missed it, remember there is one bolt that is hard to get to, and easy to forget about. This is the one that goes from the transfer case side into the trans. It's usually easier to get to once the transfer case is separated from the trans. It's the only bolt that secures it from this side (excluding transfer case bolts). This bolt is located slightly above and forward of the transfer case. It's to reach it from the top.
Old Sep 26, 2010 | 10:37 AM
tscompusa2's Avatar
yep. i was gonna mention that specific bolt also, but figured he seen it if he got to all the tcase bolts since its uptop and easy to see. but yes that bolt is retarded, and hard to even back out.. dont know what mitsu was thinking there.
Old Sep 26, 2010 | 11:04 AM
INEVOIX's Avatar
lol, it's easy to miss the first time someone does one (I know from experience..lol). I think they like to stick one random bolt in there to throw people off and make it difficult...lol
Good luck to the thread starter.
Old Sep 26, 2010 | 07:28 PM
Spoolin4g63's Avatar
if its the TOB, i would just unbolt the pressure plate from the motor and drop the tranny with the clutch and pressure plate...! I went threw this with my buddys car..
