information please (tranny)
Old Sep 26, 2010 | 09:35 AM
milford's Avatar
information please (transfer case)
Hi. so i am under my car doing some work and i notice a lot of oil residue around my drive shaft and all over my downpipe. so i look closely and see that a little drip of oil is hanging from the case right where the drive shaft is attached. it looks like oil has shot out all over my down pipe and chassis in that area. it looks like it was sprayed all over in that area.. no real problems with the transmission at this point aside from the typical high rpm gear lockout.
would somebody tell me what exactly would cause oil to be leaking out of of the case right there where the drive shaft is attached? what would a typical fix of this problem be?
thanks in advance everyone
Old Sep 26, 2010 | 04:57 PM
milford's Avatar
i believe its coming from the output seal on the transfer case, right where the drive shaft goes in..does anyone know if this is common?
Old Sep 26, 2010 | 05:01 PM
RoMeIX's Avatar
How does the transfer case look? Does the down pipe touch the transfer case at all?
Old Sep 26, 2010 | 06:09 PM
milford's Avatar
no the downpipe does not touch it. i heat wrapped the DP to keep heat away too. do you know if its possible to replace that seal without taking that tower piece off the case..im hoping i can just pull out the drive shaft and have access to the seal to remove and replace it?
Old Sep 27, 2010 | 01:40 PM
mohammed5's Avatar
I'm having the same problem. I see oil dripping all over the place ,please some body gives us more details about this problem.
Old Sep 27, 2010 | 06:26 PM
milford's Avatar
well i popped out the drive shaft today and looked at that seal right there where it goes in..looked a little bit chewed up so i popped it out and it had some damage. ordered another for 10 bucks so hopefully that helps
Old Oct 23, 2010 | 11:14 AM
pettyboy69's Avatar
im sure thats what the problem was, it is a common part to go bad
Old Oct 24, 2010 | 04:50 PM
xbeckk's Avatar
after 7 years you might expect to see more seals failing.
always inspect everything every oil change.
just my 2
aviseevuoptical
Feb 28, 2016 12:24 PM
Hype
Nov 28, 2014 10:26 PM
dillon410021
Sep 27, 2014 07:55 PM
stanlsha
Jul 12, 2011 04:04 AM
al3lwan
Oct 14, 2010 05:52 PM
