Valve guide Q
Old Sep 27, 2010 | 03:39 PM
crazy_ugly_coyo's Avatar
Valve guide Q
So I keep loosing one of my intake rockers. So far I've replaced the spring's and the retainers. The valves are fairly new as well a the retainers. So I was told to check the retainers to make sure theyre not too tight. How do I do that?
Old Sep 28, 2010 | 08:19 AM
JonDSM's Avatar
How do you loose your rocker? which part wears out?
The rocker rides directly on the valve. The position of the retainer doesn't make a difference. There is no way to check the valve spring retainer tightness.
Old Sep 28, 2010 | 11:08 AM
DarksideZ's Avatar
Hmm it appears that your valve gets stuck in the guide or gets stuck open somehow. How long does it usually take for the rocker to come off?
Old Sep 28, 2010 | 08:39 PM
As soon as I take it above 7k rpm
Old Oct 5, 2010 | 12:09 AM
mtxfrk2k1's Avatar
do you have any clearance issues with piston valve contact?
retainers being to tight would have nothing to do with it unless they wrapped all the way around and touched each other and touched. which would make you drop a valve if anything.
