My Build Thread
Old Oct 6, 2010 | 03:21 PM
AngryEvo8's Avatar
Looking good!!
Im sure you have seen the turbotrix drag car..Orange sickness.
Old Oct 7, 2010 | 01:18 AM
benderrodriguez's Avatar
Thanks for all the compliments.
Old Oct 11, 2010 | 03:35 AM
yrkesman's Avatar
Can I ask what was wrong with the engine?
Old Oct 11, 2010 | 06:19 AM
cij911's Avatar
Can you provide details on what you did to the engine ? What turbo are you running ?
Old Oct 11, 2010 | 11:20 AM
So the engine had low compression of Cylinder #2 and the clutch disks were worn out. So we pulled the motor and the trans for the rebuild. The issue with the engine was the head gasket and a warped deck.
Some specs on the motor
it's a 2.4 4G64 block and crank .20 over
Manly I Breams
Weisco Pistons
Port Polish Head
Crower springs retainers
272 cams
Ferrea +1 valves
Cometic Head Gasket (I may live to regret)
I did new pistons bearings, valves, guides, and seals. As for the machining work cylinder hone, seat and guide resurface and ream.
As far as the turbo setup its a TS GT4088
It's probably a bit much for the street but I'll still have fun with it anyway.
Old Oct 11, 2010 | 02:37 PM
TakaseEVOIXSE's Avatar
nice seeing more build threads here!
I highly recommend using the factory mitsu head gasket. (but you seem to know that already)
Believe it or not, the GT4088r (in appropriate exh A/R) will actually (from my experience) spool quicker than a 35r in T4. Only issue we had was power falling off in the top end. A 4094r holds it out better. It was really decent w/ spool on a 2.3l stroker motor. I was surprised.
Old Oct 12, 2010 | 06:47 AM
Yea I wanted to even O-Ring the head but I couldn't get someone to do it w/ a quick turn around.
the turbo is the one that came w/ the car so I'm going to stick w/ it, but if anything happens to/ with it I may try your 4094R suggestion.
I also did upgrade to a COP, and a full blown double pumper w/ -8 supply, -6 return line. Out of curiosity how much power have you made with a stroker and the 4088 on pump gas, or E85?
I've seen a couple TS GT35R's make about 600whp on 93 octane I'm hoping to at least get that.
Old Oct 13, 2010 | 12:29 PM
So a couple of progress photos, adn an update.
After a new starter and a mysterious oil leak behind the intake manifold (machine shop left our a screw plug) she is alive.
I defiantly need to work on the tune a little but it's not bad.
Thanks to Ryan for the great work!
Attached Thumbnails My Build Thread-dscf2447.jpg   My Build Thread-dscf2448.jpg   My Build Thread-dscf2450.jpg   My Build Thread-dscf2451.jpg   My Build Thread-dscf2452.jpg
Old Oct 13, 2010 | 12:32 PM
1 more
Old Oct 13, 2010 | 01:41 PM
Evokid03's Avatar
Alright i understand u spend all the extra cash on looks for the engine bay which is good, but if ur gonna spend that money and then make a mess of wiring to ruin the look whats the point?
Old Oct 13, 2010 | 02:40 PM
The wiring still needs to be cleaned up. the car overall is far from done we just wanted to get it running to see if there are any mechanical issues. Eve from a reliability standpoint I'm not going to leave loos wires hanging.
There is alto of work to be done, but now I can dive it to the painter and work on the wiring while it's there. I also didn't spend that much on looks. My total bill from the powder coater was just over 200 plus 30 extra on a timing cover(after I sold my old one).
Old Oct 15, 2010 | 02:10 PM
EVODreams's Avatar
A wire tuck would do wonders for your engine bay! Looking good though.
Old Oct 24, 2010 | 07:06 PM
I'm hoping to finish up the wiring and the paint job in two to three weeks. In the mean time here are some progress pics of the new fuel filter, catch can, mustache bar, front cross member, and battery
Attached Thumbnails My Build Thread-img_0273.jpg   My Build Thread-img_0269.jpg   My Build Thread-img_0279.jpg   My Build Thread-img_0282.jpg
Old Oct 24, 2010 | 07:19 PM
xcelr8's Avatar
Looking good! Nice build
Old Oct 25, 2010 | 05:56 PM
Well its going ok. I'm driving it now, although the starting is terrible. I'm not an amateur tuner but getting this thing dialed in right is proving to be more than difficult.
