EVO 9 oil pressure problem
Old Sep 29, 2010 | 01:14 PM
EVO9WOW's Avatar
Hi,
I have a stock EVO 9 and i have problem with oil pressure. Everything was changed , even got a new block and the problem still insists, oil pressure goes to 0 so i assume the problem is on the head?
Any help appreciated.
Thanks in advance
Old Sep 29, 2010 | 01:20 PM
javicracer's Avatar
what happen to the car before the problem with the oil psi?!?!?!?!
Old Sep 29, 2010 | 01:39 PM
awdboosted's Avatar
And also where are you getting the reading for the oil pressure?
Old Sep 29, 2010 | 11:06 PM
EVO9WOW's Avatar
Hello,
the car was imported and it was like that. When you cold start it, the oil psi is 9 bar and as the temperature goes up and psi goes down, it gets down to 3bar and on idle it goes to 0 and you can hear the rod having a party.. , as you rev oil pressure does not go up.
Parts changed twice after the car was imported and diagnosed with the problem : crank, pistons, rods, oil pump
and a few days ago a complete new block was in and still the same.
Oi pressure is measured with professional gauge at my mechanic.
Oil used : 15-50.
Thanks for your help
Old Oct 2, 2010 | 03:09 PM
barneyb's Avatar
If your mechanic can't fix it with all you have listed as being done the problem has to be the mechanic.
Old Oct 6, 2010 | 08:31 PM
signature sound's Avatar
bad oil pump. major cavitation from worn gears. when the viscosity drops, its introducing air into the system. its reading good while cold because the thicker oil is properly sqeezing thru the system. the tolerance between the gears have become too big to produce the proper pressure.
Old Oct 7, 2010 | 02:27 AM
german_evoVII's Avatar
Do you run both Balancer shafts in the Engine?
Did you checked the rear Balancer bearings ?
Where is the Oil Pressure sender ?
Stock Evo9 should have a max of 7 Bar ( Oil is cold , @2000 RPM), 1.5 -2 Bar warm engine @ idle
In no way you can loose that much pressure in the head alone. Its somewhere in the Block.
Where are you located in Europe ?
Steffen
Old Oct 23, 2010 | 10:59 AM
pettyboy69's Avatar
how did the bearings look? How about the oil pump? i would think the only way the head could be loosing the oil pressure is if it's cracked which is unlikely. Were the bearings checked for corrrect clearences?
Old Sep 19, 2011 | 02:02 AM
Raul_evo9's Avatar
did you find the problem?I have the same problem with my evo 9RS.
thanks.
EvoX267
Sep 18, 2015 11:21 AM
Capes
Feb 9, 2014 02:27 PM
cdsalwathura
Oct 12, 2012 10:09 PM
TeachersEvo
Oct 10, 2012 10:57 PM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
