Evo VIII transfer case leak?
Old Mar 2, 2012 | 08:28 PM
impact blue's Avatar
My cars leaking too I hate this crap and I just had it rebuilt what the hell Its the seal that leaked on the passenger side where the axle is.
Old Mar 4, 2012 | 07:54 AM
AJCaron12's Avatar
Originally Posted by evo8uson
Yeah I guess it has to do with a copper washer that I didn't put in I'm working on it now. Do you have the copper washers in?
What copper washer? Dude I haven't even started pulling my TCase yet. I'm gonna get all the parts together first.
Old Mar 4, 2012 | 07:55 AM
AJCaron12's Avatar
You have a different leak than what we're talking about. It sounds like you have an axle seal leak, you don't need to remove the transfer case to replace axle seals so consider yourself lucky.
Old Mar 4, 2012 | 10:19 AM
delongedoug's Avatar
^ correct
Old Mar 4, 2012 | 04:43 PM
kristian4802's Avatar
Subscribe
Old Mar 8, 2012 | 05:32 PM
89turbosupra's Avatar
Im having the same leak from between the transfercase and tranny. I wanna make sure i get two of every seal/washer that it could be. I cleaned off the area today with some brake clean and gonna look at it again tomorrow. How long doesnt it take u guys to remove the tcase?
Old Mar 10, 2012 | 11:40 AM
Walt's Avatar
Removing the t-case is a pita.. It took me about 4-5 hours on my back.
Old Mar 11, 2012 | 02:17 PM
Thanks for the heads up. I was excpecting that kinda time. Still not too bad though
Old Mar 12, 2012 | 08:09 AM
evo8uson's Avatar
Yeah the copper washer is what caused mine I fixed it about a week and a half ago and its been good no leaks at all...you'll see there is a hole that has a small lip to it, that's where is goes I put it in and used some mitsubond gasket stuff and not a leak or wet spot.
Old Mar 15, 2012 | 06:13 AM
Ramonski's Avatar
^^^can you elaborate on the specific location of this copper washer? I'm about to replace my seals and I just want to make sure I check everything while it's off
Old Mar 15, 2012 | 09:44 PM
devildog08's Avatar
good luck with the fix i had a similiar problem an i changed the seals
Old Apr 3, 2012 | 01:39 AM
MrJuls's Avatar
So how does one replace the oil when it needs to be replaced?
Old Apr 3, 2012 | 01:53 AM
AndyCT9W's Avatar
http://www.evomoto.com/tech_info.php?tPath=2&tech_id=25
Just did this yesterday on my JDM IX GT.
Old Apr 3, 2012 | 01:58 AM
MrJuls's Avatar
Thanks very much.
Old Apr 3, 2012 | 02:05 AM
MrJuls's Avatar
Can i use this Evo Motorsports site for my IX info as well or is there a similar site for the IX?
