What is causing this camel hump (dyno)?
Old Oct 11, 2010 | 06:01 PM
kyoo's Avatar
Originally Posted by Ian0611
My dyno graphs were looking the exact same way for a while and it turned out to be a couple of different things. One of the problems was that I did have a small boost leak, however my graphs were still looking like that even after I fixed it. The real problem ended up being the boost tables in my tune. I thought I had them dialed in but apparently they needed more fine tuning. Keep in mind that I'm using ECU controlled boost with a modified stock boost solenoid so I'm not sure how much those tables affect an MBC. I'm sort of a newb in that area cuz I've only been tuning my car for a few months now and ECU controlled boost is all I've ever had. So based on what little I know I'm thinking there could still be an issue in your tune that's causing the problem. Could also be your clutch like someone else suggested.
thanks - the clutch is brand new so i'm thinking it may be the tune. we'll see how it goes! Thanks
Old Oct 11, 2010 | 06:47 PM
Ian0611's Avatar
Yeah again I'm not real familiar with tuning MBCs but for my setup I made some adjustments to the Boost Error Correction Table and the Max Wastegate Duty Cycle Table and I was able to get a much smoother graph and more power. The weird thing about it was that I found that making adjustments in the upper rpm ranges helped smooth things out in the lower ranges. I didn't believe it at first so I tested it out a few times and sure enough I'd make changes to the MWGDC around 6000rpm and my dyno graph would get smoother or choppier around 3000-4000rpm depending on the setting at 6000 I don't really understand why it was working that way I just know that that's what it was doing and I have logs to prove it in case someone thinks I'm off my rocker and I don't know what I'm talking about.
Old Oct 11, 2010 | 06:59 PM
kyoo's Avatar
gotcha - ams said they wanted to retune me so i'll see how it goes - provided that i dont have a driveshaft bearing going (https://www.evolutionm.net/forums/ev...gging-car.html)
kyoo
Apr 20, 2010 02:42 PM
kyoo
49
Apr 5, 2010 06:54 PM
kyoo
Feb 3, 2010 02:54 PM
kyoo
16
Jan 20, 2009 10:30 PM
kyoo
Apr 14, 2008 11:50 PM
