Unusual Squeak - Help!
Old Feb 12, 2010 | 07:46 PM
kyoo's Avatar
mods - i apologize but I HAD to make a separate thread about this noise - it's really strange - please keep it separate for at least for a short period of time -
This noise is:
- a squeak coming from inside the dash in front of the driver
- it is somewhere from around the vents near the windshield
- when the car is cold, it will squeak to absolutely ANY vibration - including vibration from the engine (say, if you almost let the motor stall with the clutch, it will sound like a cage full of mice), even just normal driving engine vibration
- when the car has been driven for a while (i don't mean warmed up, it will still do it then, but after the car has been driven for a while), the noise completely disappears.
- if i turn off the car for a little and let it sit, and then drive it again, the noise comes back!
What kind of squeaking noise disappears just cuz you've driven the car for a while, and comes back?? Also, it's been persistent for about 1.5-2 years
Any ideas at all? Has anyone had this noise???
I'll try to take a video later if I get a chance.
EDIT: VIDS
A big thank you to mods for allowing me to keep this thread separate and not merging it with all the other noise threads - I think it will help me crack down what is causing this particular squeak.
Old Feb 12, 2010 | 07:50 PM
detroit pistins's Avatar
so u have had this noise for 1-2 years and ur asking now?
what type of clutch do u have in? did u notice the noise appearing after u throw in the new clutch?
Old Feb 12, 2010 | 07:53 PM
kyoo's Avatar
lol i've kind of lived with it but i'm taking care of my car bit by bit and this was next on the list. i also have a cracked windshield, need to get a license plate holder for my jdm rear, etc etc etc.
I actually just got a new clutch today - same noise as before it and after it.
I honestly don't think it's anything mechanical, really sounds like a squeak coming from inside the car, the dash
But it's also weird that the noise will disappear after driving for a while which would maybe suggest it's something mecahnical or something like that
Old Feb 12, 2010 | 07:57 PM
revvin9k's Avatar
How big is the crack in the windshield?
Could it be that? When did it start?
Old Feb 12, 2010 | 07:58 PM
kyoo's Avatar
crack in the windshield is a little less than half way.
I don't think it's the windshield.. pretty sure it can't make that kind of noise. The noise was there before the was cracked anyway
Old Feb 12, 2010 | 07:59 PM
list all of ur mods
Old Feb 12, 2010 | 08:06 PM
kyoo's Avatar
gauges by Trustz - just a gauge overlay
hks type 1 turbo timer
brake shims, ferodo ds2500s front and rear, ss brake lines
jdm rear and crash beam
vortex generator
GSC S1 cams, ARP headstuds, megan o2 housing, AMS fmic, lcip, apexi filter,
5 speed shifter bushings
cusco catch can
tanabe downpipe, cobbtest pipe, buschur catback
aftermarket HIDs
uk IX badging, short antenna
orbital double din kit
JDM double din with pioneer avic f90bt
tints, valentine1
bilstein hd struts, gtworx springs
whiteline bumpsteer kit, rear trailing arm bushings, front control arm bushings, roll center adjuster
exedy twin, ss clutch line, tob, clutch fork stopper
i think that's most of it:
Old Feb 12, 2010 | 08:07 PM
kyoo's Avatar
of those i guess the most likely things are gauges - though i'm not sure how
or the navigation system - not sure about timing though
the HIDs i guess COULD be possible except that the noise is definitely from the inside..
sounds like i'm gonna pull the dash apart - anyone got a quick how-to thread link for that?
Old Feb 12, 2010 | 08:12 PM
ok when u turn on the car whether its cold or warmed, u hear the twin clutch makes some sort of a "chatter" noise correct?
cuz iam thinking it might be ur clutch that ur hearing and u think it coudl be something else. its normal for the twins (and some single clutches as well) to make that noise from what i have heard.
Old Feb 12, 2010 | 08:14 PM
kyoo's Avatar
yep - but the clutch i just got literally today, just got back from Strictly Modified.
The squeak has been around for very long, and it definitely sounds like its from right under the plastic dash in front of the driver. the clutch does chatter though yea, but not as bad as i thought it would
Old Feb 12, 2010 | 08:21 PM
well when u were at strictly modified, did they hear the noise? u shoudl have asked for thier opinion.
this is wierd, iam curiouse to know whats making this noise now.
Old Feb 12, 2010 | 08:23 PM
kyoo's Avatar
I'm not sure, I basically just dropped the car and picked it up, was in a slight hurry at the end of the day. I think I'm just gonna have to pull the dash apart in the spring or something... Hopefully it will be an obvious simple fix
Old Feb 13, 2010 | 07:22 AM
oneofakindtrini's Avatar
Wow man, talk about not taking care of your car. A cracked winsheild, and you continue to drive it? You bought a JDM rear and no license plate hold for it? Then you have been hearing the noise for 1-2 years and you've just ignored it? Ok, you should make some time and take the car in to a EVO specific tuning shop and let them have a look at it.
Old Feb 13, 2010 | 07:33 AM
kyoo's Avatar
lol the car's been sitting for about 5 months now, I put it away for the season right after the window cracked. and a lot of people use zip ties to hold their plates for jdm rear, i really dont understand the creating your own plate holder thing people do
..so any contribution about the noise or did you just stop by to judge me? lol
Old Feb 13, 2010 | 08:25 AM
BoostKid87's Avatar
how long does the squeak last for? or is it like a quick squeak every time you hit a bump?
