up for a 500 whp quick spooling turbo
Old Oct 11, 2010 | 01:53 PM
Sean@Iveytune's Avatar
FP stuff is great I have used a red since back in 2001. Good stuff and innovative guys there.
This is yet another offering in the market, and it is the only turbo that makes over 450 wheel hp that spools like stock I mean just like stock if not better.
Sean
Old Oct 11, 2010 | 02:03 PM
keath's Avatar
I have a red but wish i had HKS..
BB turbo enough said
Old Oct 11, 2010 | 02:14 PM
RockmanX's Avatar
Sean
turbo is 1800 right sean so in your honest opinion on average on 93 oct fully built 2.4 and head of course could this lay down 525-550. NO meth injection just straight pump gas only??? or is one basically going to make 450-470 just better spool??
Old Oct 11, 2010 | 03:40 PM
SmurfZilla's Avatar
Originally Posted by dyezak
3. HKS is cheaper, especially if you are in an Evo8. For the 8 guys you need to buy a green, and the install kit. That throws you well over $2000 for a bolt on turbo. The HKS is $1899 and comes with the install kit for an 8 (or 9).
The install kit (cams and springs) is a limited run and after this the turbo ONLY will be 1899. Thats still a smokin deal for a stock frame BB turbo that seems to perform with the Full and HTA green.
Old Oct 11, 2010 | 03:45 PM
GR8WHITE RS's Avatar
fp-red and a good tuner should do the job. or a hta fpgreen on e-85 ;-). gotta love the corn.
Old Oct 11, 2010 | 03:48 PM
dbsears's Avatar
Why would you think it would lay 525-550whp down on strait pump? There is hardly anybody even achieving that with an FP Black with built everything...I would highly doubt even your setup will lay those numbers down unless pushed hard. That HKS turbo just doesn't have the airflow for those numbers. Your later guess would be more in the ballpark most likely from whats been done by others.
Old Oct 11, 2010 | 03:51 PM
buchnerj's Avatar
Originally Posted by toysgetsmoked
To hit 500 whp on a red is a bit hard so the black will be a great choice for your Turbo.I personaly don't like stock framed turbos went threw . Of them and nothing feels like a t3 large frame.the 60-1 is a nice all out Turbo makes great power and spools fast..
This is completely untrue. I was hitting 510/520 on a Green. I have a red on the car now and am working on the tune. Numbers on it to follow.
HKS looks like a great turbo, but don't spread misinformation about other products when you don't know the truth about them.
Old Oct 11, 2010 | 04:00 PM
xcelr8's Avatar
my car did 600whp on e85 on a red. On pump off wastegate boost only before SD tune it made over 440whp. I dont ever run pump so its pointless to me to see how much it could make.
Old Oct 11, 2010 | 04:14 PM
JohnBradley's Avatar
Alot of what turbo you want depends on what fuel you plan on using and what supporting mods. 91 octane, 93 octane, E85, pump meth, etc. Normal power on a Red on 91/92 octane is mid 400s. You can always make more but alot depends on total combination.
Aaron
Old Nov 22, 2010 | 11:08 PM
AdamWest's Avatar
personally i would like to see how the hks performs... but id rather stay safe and rep the ol' red
Old Nov 23, 2010 | 10:18 AM
Broham's Avatar
Rockman,
Are you having doubts regarding your black? the hks sounds great and is good to be bb versus fp journal, but isn't the issue on exhaust gas temps etc still a problem on the new hks and fp blacks?
Old Nov 23, 2010 | 11:39 AM
doc29's Avatar
NOT AN ISSUE ON THE HKS...cant speak on the black..
Old Nov 23, 2010 | 11:48 AM
dinok's Avatar
my boy has a 64mm fp red with 550whp on 30psi tuned by dynoflash
im on a 84mm surge port fpred on LOW boost 440whp
Old Nov 23, 2010 | 12:01 PM
doc29's Avatar
more power will come from the red...the hks just moves the powerband to the left..torque is just there instantly...in many ways better than my cars that have large displacement and are naturally aspirated...there power builds with rpms...evo has it from 3000 rpms to redline...evo gets most seat time...
theblackbeast11
10
Mar 26, 2013 03:13 PM
yenny
Jul 31, 2012 07:06 PM
MRadjahoe
40
Jan 20, 2012 09:27 AM
EVOEMS
11
May 5, 2008 08:42 PM
cetinsaya
103
Jan 22, 2008 07:13 AM
