ets t3 kit 6262 or 6266 or 6466
Old Feb 23, 2013 | 12:30 PM
theblackbeast11's Avatar
What turbo would be best.
my goal is over 900 one day we talking 5 years down the road. but i am on stock turbo right now and want to put a t3 kit on there and make 500whp.
what turbo do you guys think would be best for this and why. remember going t3 because 900whp later in the cars life so all will have to do is switch turbos out. so what turbo to make 500whp is best right now car is a dd will be not a dd later this year when t3 goes on. ALL ready putting in a triple disc exedy why because race car haha...
Old Feb 23, 2013 | 12:36 PM
sLowEvX's Avatar
6466 just do it right the first time. The 6466 spools like the 6266, but has much more top end for your future plans.
Old Feb 23, 2013 | 12:42 PM
I have heard it spools a little later idk tho.
and was thinking about doing a 6766 later just because 936 whp haha hey that extra 36 hp would be the new record....
Old Feb 23, 2013 | 02:32 PM
sLowEvX's Avatar
The 6466 is almost identical as far as spool goes in almost every Dyno sheet when comparing to the 6266. The 6466 is capable of 1000whp
I wouldn't sacrifice the spool for the minimal gain you may get up top from the 6766. That's just me.
Old Feb 23, 2013 | 03:19 PM
Yea i see the 6466 is capable of 900 I have not looked that turbo up tho. Have you seen dyno sheets where it has made 1000?
would like to see them i will look into that turbo
Old Feb 23, 2013 | 07:49 PM
evokid4life's Avatar
6466 ftw!!!
Old Feb 23, 2013 | 10:48 PM
sLowEvX's Avatar
The 900whp that PTE lists it at Is just were the turbos efficiency range seems to end but not max HP. Just like we see 6266 's in the 800's but its only labeled at 735whp.
Old Mar 25, 2013 | 08:48 PM
boostaddict10's Avatar
would this be a 64/66 on a stock motor then eventually building it. I was thinking about doing that and leaving boost at a moderate level and then cranking it up once motor is built
Old Mar 26, 2013 | 10:45 AM
murlo26's Avatar
Put a 5858 on there now for 500whp, then sell that later and put a big *** turbo on there.
You will hate driving a single scroll 6466, its laggy as sin and with a stock motor you won't even be able to rev it out to utilize it, you'll have a 1000rpm power band of crap.
The 6266 and 6466 aren't the "same" in spool, they are for sure different, you don't get the same spool out of a turbo that is capable of 100-200more whp, sorry.
But regardless, don't do a big *** turbo now, you won't want to drive that for 5 years.
Old Mar 26, 2013 | 03:11 PM
so murlo you think a t4 twin scroll 64-66 wouldnt drive good on a stock motor
Old Mar 26, 2013 | 03:13 PM
murlo26's Avatar
It would drive alright, but I don't see a reason for such a setup on a stock motor, WAY overkill, especially for 5 years of time.
If it was a few weeks or maybe months, then sure why not, but no reason to gimp your car just to have a big *** turbo on there.
He also mentioned a t3 kit not t4 ts, different setup.
Jkuti13
22
Sep 16, 2016 08:17 AM
5LEEPERISAH23I
Jan 15, 2016 06:18 AM
Hotsauce101
Oct 18, 2015 06:02 PM
Bigboost1320
12
Jun 22, 2015 03:44 AM
3gEclipseTurbo
68
Jun 27, 2010 06:33 AM
