SFP turbo kits now released.
Old Nov 29, 2003 | 01:54 PM
Zeus's Avatar
Originally posted by Turbo Weapon
id seriously consider the E50 trim with .63 a/r turbine housing and stage 3 turbine. that combination has made over 450whp on pump gas and gone 11.0@12X mph and spools in the 3600-3700 range.
That sounds real nice... but I'd have to see it.
Old Nov 29, 2003 | 04:12 PM
5StarSuzuki's Avatar
In Timeout
3 Questions:
1) Will you be offering any of the GT-R series turbo's. IE. Garret GT35R
2) Whats the diameter of your intercooler piping? How does your intercooler fit with the bumerbeam and undertray?
3) Are you a vendor for aquamist?
Old Nov 29, 2003 | 06:24 PM
SFPRacing's Avatar
Yes I'm sorry the BOV is a typo error on stage 1. Copy paste and edit action got a bit out of hand. LOL.
As for GT series turbo's yes. I believe we have a GT30 on designmanfx's car right now. The beauty of our fabrication ability is that we can practically make anything you want as long as we have an evo in the shop to mock it up on for fitment. That lately hasn't been a problem. There are 3 or more of them around at many times.
Old Nov 29, 2003 | 08:13 PM
SLOPOK EVO8's Avatar
Will you offer a ball bearing option for the turbos? Approx when should/would the 60-1 trim and sc61 turbos spool up and acheive full boost (21psi)? Do you have any pics of your intercooler? Thank You.
Old Nov 29, 2003 | 08:52 PM
Zeus's Avatar
Originally posted by 5StarSuzuki
3 Questions:
#2 is a very good question...
Old Nov 30, 2003 | 10:45 AM
SFPRacing's Avatar
The intercooler piping is 2.5" mandrel bent. We can make it work with your factory IC or our FMIC. Pictures of the FMIC and piping...
The 60-1 and SC61 have similar spool times with the 61 being only slightly larger. With a .48A/R backhousing the 60-1 should make full boost at approx. 4K rpm. Just remember though it will be spooling and pulling well before that. The SC61 is only a few hundred rpms slower. Put it this way my SC61 .63A/R on my 2.0L vtec honda makes full boost about 4300rpms and the boost hits like a hammer.
We can supply ball bearing options in some of the turbo configurations. I just have to see what's more readily in stock at my distributor.
Old Nov 30, 2003 | 11:32 AM
bpclements's Avatar
Are you able to retain the undertray with your fmic?
Old Dec 1, 2003 | 10:29 AM
SFPRacing's Avatar
Yes we can retain the undertray on your car.
Note: I made a mistake about designmanfx's car. It's got our stage 3 turbo (SC61) not a GT30. But never the less we can do GT series turbo's if you want.
Old Dec 1, 2003 | 11:03 AM
clappton's Avatar
On your downpipe, is the stainless a lot lighter than the mild steel? Also, do you make an O2 eliminator downpipe? How restrictive is the stock O2 housing?
Old Dec 1, 2003 | 11:55 AM
RADmitsu's Avatar
Very good question, i was just thinking the exact same thing myself...
Old Dec 1, 2003 | 12:17 PM
slowTsi's Avatar
The dp will have an o2 eliminator as the stock piece will not boly up to a t3t4.
Old Dec 1, 2003 | 07:06 PM
SFPRacing's Avatar
The SS is only slightly lighter than the mild steel unit. I prefer the mild thermal coated. No maintance like SS but looks much nicer long term. Also keeps the heat in the DP in the DP.
Yes the DP's are all 02 eliminator style. If you need an 02 eliminator DP for stock turbo I can supply that as well. I also carry one for 1G and 2G DSM turbo's.
Old Dec 4, 2003 | 06:21 AM
SuPaNooK's Avatar
is this setup installable for any local shop?
since im at vegas....im not sure if i would have a shop install your turbo or what not...
Old Dec 4, 2003 | 06:29 AM
SFPRacing's Avatar
Yes this is a completely bolt on kit. The stage 3 takes some AEM tuning by an experienced tuner. Of course we are always available for technical support in the unlikely event you should run into any problems.
Old Dec 4, 2003 | 06:35 AM
Pesto360's Avatar
I can vouch for these guys...any remote small issue they handle IMMEDIATELY and address and fix the problem...You wont find a better shop in South Florida....
AHEM....today...we go to the dyno...hope to put over 500whp down on STREET fuel (with a little help from aquamist)...any and all are invited to witness
