Can I run E85 on 93oct Tune?
Old Oct 15, 2010 | 01:08 PM
TGZ's Avatar
TGZ
Hey guys,
An E85 pump finally opened up not too far from me. I am currently tuned for 93oct only.
Can I fill up on E85 to get the added benefits of higher octane without being tuned for it, or will my car run worse?
Cheers!
Old Oct 15, 2010 | 01:12 PM
grillpt's Avatar
NO!!!!!
Try the search function, or the alternative fuel thread.
Old Oct 15, 2010 | 01:18 PM
talon91guy's Avatar
You could run into a lean condition and that can lead to problems. Remember that it takes almost twice as much to burn E85 than it would regular pump gas. Someone please correct me if I am wrong.
Old Oct 15, 2010 | 01:21 PM
TxEvo8's Avatar
No you cannot, you need bigger injectors and fuel pump to deliver enough e85.
Old Oct 15, 2010 | 01:22 PM
SyZyGy1394's Avatar
twice as much wat?
4RETECH's Avatar
You need to have injectors to handle it and a tune before blowing the engine up.
Old Oct 15, 2010 | 01:23 PM
TGZ's Avatar
TGZ
Originally Posted by grillpt
NO!!!!!
I tried searching but most combinations of words I tried would not be used because they were too common. I don't have under 10 posts in 8 years by not searching often.
Old Oct 15, 2010 | 01:24 PM
TGZ's Avatar
TGZ
I have a Walbro and 1200cc injectors. My question was regarding the tune. I am familiar with what is required to run E85 from the mechanical side.
Old Oct 15, 2010 | 01:26 PM
grillpt's Avatar
Last edited by grillpt; Oct 16, 2010 at 07:06 AM. Reason: You can read others quotes if you wanna see what I said.
Old Oct 15, 2010 | 01:31 PM
TK40's Avatar
No offense but if you've been on here for 8yrs you would know the answer to your question... If you do some research in the thread I mentioned you'll find all teh info you need.
Man you sure are a snob.
Old Oct 15, 2010 | 01:42 PM
mega-z's Avatar
O Snap!
Old Oct 15, 2010 | 02:33 PM
tscompusa2's Avatar
e85 will require timing tweak at peak torque along with richening the fuel big time since e85 uses 30% more fuel. - not to mention injector size rescaling and deadtime latencies.
Old Oct 15, 2010 | 02:35 PM
JDMevoBOOST's Avatar
really bad idea
Old Oct 15, 2010 | 04:54 PM
Joshs EVO's Avatar
No you can't.
Old Oct 15, 2010 | 08:59 PM
Ted B's Avatar
That will be just enough fuel pump to get you close to 500whp and no more.
However, pumping E85 onto a 93 octane tune will result in a severe condition. Basically, the car will be undrivable.
To use E85, you will need to be tuned for E85.
