How much Boost can a stock block hold?
Old Oct 25, 2010 | 08:16 PM
5LEEPERISAH23I's Avatar
title says all ment to write with Meth injection in the title...
im doing Meth injection very soon and would like to know what is a good target boost level that is too crazy.. guess what im trying to say is what do most people run with an FP Black n Meth boost wise
Old Oct 25, 2010 | 09:03 PM
SmurfZilla's Avatar
Boost shouldnt be the question....TQ should be....most people say keep it under 450 lb of tq.......obviously there are some that like to tempt fate.
Old Oct 25, 2010 | 09:17 PM
4g63Moon's Avatar
got a friend with a stock block with fp green running 25 pounds are has no problem. You should be alright as long as its under 30
Old Oct 26, 2010 | 07:10 AM
you are right about keeping it under 450tq... just like i just couldnt run 35PSI on a stock block it would blow up!
what could be a DD PSI level that isnt ridiculous
Old Oct 26, 2010 | 07:14 AM
coolguyuno1's Avatar
I'm pushing 32 psi without issue on E-85 and stock block.
Old Oct 26, 2010 | 08:03 AM
how long have u been driving it with 32 PSI?
Old Oct 26, 2010 | 08:21 AM
mt057's Avatar
I have been running 30-32 for a few years and something around 50000mi. Stock block and head except for cams and cam gears.
Old Oct 26, 2010 | 08:35 AM
dan08's Avatar
Im at 30 psi on E-85, stock block.
Old Oct 26, 2010 | 10:07 AM
Turbo01s2k's Avatar
I run 29psi on a stock block with my 35r. No issues for atleast 5k miles
Old Oct 26, 2010 | 10:15 AM
RyuEvoIX's Avatar
I've ran as high as 46psi on the fp black which produced 580wtq @4050rpms. That was due to a boost controller malfunction but the dyno recorded it before I was able to abort the pull. These motors can handle a ton, I daily drove over 500wtq on my FP Red @38psi daily for over a year.
Old Oct 26, 2010 | 01:02 PM
ok so after seeing all of this i think it is safe to say im good run 30PSI n DD it with meth!
Old Oct 26, 2010 | 01:41 PM
mithrandir7533's Avatar
Is everyone running these high boost levels with upgraded head studs???
Old Oct 26, 2010 | 01:43 PM
gieri002's Avatar
It all depends on the condition of your internals...
Old Oct 26, 2010 | 01:59 PM
Im running head studs
Old Oct 26, 2010 | 05:16 PM
Jerm__'s Avatar
Ya, isn't boost irrelevant? shouldn't you be just concerned with hp/tq?
You can have a tiny turbo at 30psi but if its not putting much power/tq, then why would they you be concerned about your block?
