Fpred Max HP on a Mustang Dyno
Old Oct 26, 2010 | 11:14 PM
Srt4...'s Avatar
I'm going with a Fpred and I was curious what is the max power ppl have seen with it on MUSTANG DYno on a fully built motor and head and supporting mods
For example
jam 2.3 stroker
jam stg2 head
Everybody that puts out good numbers has a dynojet which always reads higher than a mustang dyno. What will the fpred max out at hp wise?
Thx
Old Oct 27, 2010 | 02:52 AM
bbyevo8u's Avatar
what kind of fuel are you going to be using?
Old Oct 27, 2010 | 02:17 PM
Srt4...'s Avatar
e85 would be the fuel
Old Oct 27, 2010 | 02:18 PM
Srt4...'s Avatar
the only other high hp results on a mustang dyno is TTP engineering
Old Oct 27, 2010 | 02:31 PM
surferjeff's Avatar
They have high hp results because they push the cars to their limits. My 05 GSR made 488whp/486tq at 41.8psi in 4th gear uncorrected on E85, HKS 280 cams and stock motor on the FP Red, twin pump and 1600cc injectors with MAF sensor. My best to date is 11.00 @ 130mph on street tires with a ****ty ACT HDSS organic street disc.
Built engines will not make more power unless the compression ratio is higher and /or the displacement is higher like a stroker. Headwork on a small turbo like the FPRed is not worth it as it will just run out of air sooner in the rpm band, especially with a stroker.
Ryuturbo is another one with 54X whp on meth injection and FPRed, stock motor. He just moved to a HTA82 ball bearing turbo though since all his stock frame turbos were failing.
Shacochis06
Jan 14, 2015 06:12 PM
mtxfrk2k1
Feb 14, 2014 06:49 AM
bbyevo8u
Jul 15, 2012 11:41 PM
MR. EVO MR
Sep 29, 2009 06:03 PM
kcevo
Sep 22, 2009 07:55 PM
