Compressor surge
Old Nov 2, 2010 | 04:27 PM
HumanWeapon's Avatar
Compressor surge
I have an Evo 9 with a 20g turbo and there is compressor surge. not while spooling but when i shift, with the BOV. would a different BOV fix this problem?
Old Nov 2, 2010 | 04:40 PM
evo420's Avatar
what do you have?
Old Nov 2, 2010 | 04:41 PM
evo420's Avatar
you sure the vacume lines are corect?
Old Nov 2, 2010 | 04:43 PM
evo420's Avatar
what is the simptoms? need more input
Old Nov 4, 2010 | 02:06 PM
The BOV is stock. And I haven't checked the vacuum lines. Symptoms are just the chatter when the pressure is released.
Old Nov 4, 2010 | 04:46 PM
Gocu619's Avatar
I had the same problem on my EVO IX MR... I have a stock 9 DV when I bought it from the dealer. The problem was that the DV/BOV was installed backwards probably when they restored it back to "stock". See if that helps.
Old Nov 4, 2010 | 05:44 PM
05VIII's Avatar
You are experiencing bov flutter not compressor surge.
Causes are bov on backwards, bov line has a leak, vac line popped off somewhere, or a boost leak somewhere. Do a boost leak test and fix any leaks you got.
Edit: of the bov is installed backwards then it will be compressor surge. Make sure it's on the right way
revhappy
Jun 13, 2011 07:30 PM
Mosaic
Aug 21, 2010 12:34 AM
AlwaysinBoost
12
Nov 26, 2006 04:28 PM
EVOlutionary
13
Sep 13, 2006 07:17 PM
evo racing
Apr 24, 2006 12:14 PM
