non ACD t-case and rear diff
Old Nov 10, 2010 | 04:31 AM
4ukc's Avatar
have a couple of questions:
1) I have a non ACD t-case as I understand its open diff as there were no with LSD front diff, is it possible to change open diff for RS one and what do I need for that exept RSdiff?
2) I have also non ACD rear diff is it LSD or also open?
Old Nov 10, 2010 | 05:46 AM
94AWDcoupe's Avatar
1) rs lsd diff is direct drop in. the rs lsd diff can also be found in the acd t-cases.
2) rear will have lsd. there were no open diffs for rear for evos.
Old Nov 10, 2010 | 07:45 AM
4ukc's Avatar
thanks bro
Old Nov 14, 2010 | 10:24 AM
C130flyer's Avatar
its easy to put in, I did mine 2 days ago.
pull DP and CV axles. remove inner shaft from driver side. drain case. remove cover remove diff assembly. open the assembly, remove open diff, install LSD diff. put it back together. don't forget to reservice tcase after 20 miles.
when you put it back together you must make sure both sides of the carrier and ring gear line up the same way they were before. Mark it with a paint pen or something.
DontStopMe
Feb 13, 2017 08:22 PM
dillons13
Apr 24, 2016 05:13 PM
desertsoldier22
Feb 17, 2016 08:51 AM
amsevokid
Feb 11, 2016 04:15 PM
Ian0611
Dec 17, 2015 02:27 PM
