Hose Popped Off - Now Lacking Power
well to add my 0.02 not to diss you im gonna educate you, first and foremost anytime you have a coupler pop off never ever never ever ever ever tighten up the clamp with a screwdriver, socket only.....anytime your pushin that much air pressure through the pipes you wont get it as tight with a screwdriver, now personal recommendation when you have a day, get under your vehicle start at your licp off the turbo when cold spray some hair spray on the pipe put the rubber over it and tighten each clamp up as good as you can almost to the point of breaking, tug on the pipe make sure its tight, go to the next clamp till your up at the throttle body, now for ****s and grins i have an 03 too, too make sure you wont have a problem again for a while ziptie EVERY vacuum line on your intake manifold down to make sure they wont pop off.....
now after you read this, go do all that and report back your cars powered restored.
good luck
dastallion out
good luck
dastallion out
what boost are you trying to run? have you messed with boost cut delay / fuel cut timers yet? also i agree with everyone else to perform a boost leak test. see here how to make your own: http://www.vfaq.com/mods/ICtester.html
How often do stock tubes crack or need to be replaced? and if I were to replace them what are some recommendations for replacement parts other than Mitsubishi? (The upper hose alone is over $80 from Mitsu parts).
Have any of you made your own tester? I will need a drill for the valve stem to fit into the PVC cap, right? I have absolutely no tools other than a common tool set with screwdrivers and sockets. Ah, if only cars would fix themselves... haha
Im gonna say you also either blew off the vac line to the fpr of or it ripped.
The bogging is knock which would mean lean afr. A boost leak anywhere else would cause a rich afr, which wouldnt cause a bogging it would be more of a drag. rich afr= less power in boost all the time, lean afr= bogging and knock which can be in spurts of power no power.
Trust me Ive had every kind of boost leak there is.
I bought mine here. Fast shipping also.
kaydo36
Lancer Troubleshooting
Aug 30, 2016 08:07 AM
KnightRider9
16
Nov 3, 2015 07:09 PM
Ludikraut
16
Nov 28, 2011 10:03 AM
