for anyone that has crankcase pressure issues
Old Nov 24, 2010 | 07:31 PM
  #181
l2r99gst's Avatar
Originally Posted by n2oiroc
im a proponent of keeping it as simple as possible. to me a pcv valve is another component that can fail and cause a headache. does it have benefits? sure! but its also a great spot for boost to get into the crankcase if it fails.
There's nothing wrong with your reasoning. As long as you are aware of the advantages and disadvantages both ways, then the choice is yours.
Originally Posted by buchnerj
I have run oil analysis on my oil changes before. I will do one after 1000 miles with the PCV deleted and try and show a change in water levels in the oil. I will post up my results to see if it really makes that big of a difference.
That would be a great test and I was going to suggest doing that. However, maybe not just 1000 miles. You have your old tests. Run a few more...3000 miles, 6000 miles, 10000, etc, etc and see if notice any particular trend. Water is one, but maybe increased metal levels somewhere else if the moisture is causing corriosion, etc.
Old Nov 24, 2010 | 07:37 PM
  #182
tscompusa2's Avatar
Originally Posted by rodent
For drilling out the VC, I used one of these:
Worked great!
does that work better then a regular drill bit?
Old Nov 24, 2010 | 07:44 PM
  #183
n2oiroc's Avatar
oh yeah, especially in thinner sheet metal. regular bits make triangular holes, unibits make round holes. harbor freight has a pack of 3 assorted sizes for $10 and they are decent quality.
Old Nov 24, 2010 | 07:45 PM
  #184
JohnEB's Avatar
Only problem I found with that was it leaves a stair stepped hole.... A Forstner bit or flat bit or auger style works good too.... Your right though Shawn those do rock, I use mine a ton!
Old Nov 24, 2010 | 07:46 PM
  #185
tscompusa2's Avatar
so link me to the bit you guys recommend lol. i havent bought the drill bit yet, just the tap so far. i have to use a smaller bit anyways to drill a hole lower and then connect it with the original since the hole sits so high on the valve cover. but link me to the bit that will make the final 5/8 hole the easiest
Old Nov 24, 2010 | 07:50 PM
  #186
JohnEB's Avatar
If you want a clean hole then this is the type I recommend. If your going through thin metal then all in one posted will work.
http://upload.wikimedia.org/wikipedi..._Bohrer_01.jpg
Old Nov 24, 2010 | 07:52 PM
  #187
n2oiroc's Avatar
here are the bits i use, but for what you plan on doing you are probably going to need to do it with a strait bit and a board clamped to it.
http://www.harborfreight.com/3-piece...lls-91616.html
  #188
rodent's Avatar
Mine did a 3/4" hole without the step on my VII VC. The steps are wider on mine than in the picture. Worked better than I thought. They sell them at Harbor Freight. I used JB Weld to glue the -10AN bung but now I wish I would of tapped it and used a threaded bung.
Another way to tell if you're venting enough is to hook up a cheap boost/vacuum gauge to the VC one of the vent tubes and make sure you're not building pressure inside.
Old Nov 24, 2010 | 07:53 PM
  #189
JohnEB's Avatar
Your going 5/8 (npt)???
Old Nov 24, 2010 | 07:56 PM
  #190
rodent's Avatar
Those are my bits.
I used the one in the middle which explains why I did not stair step mine when doing a 3/4" hole.
I did not clamp mine down. The magnesium is like drilling through alum and it felt fine just holding it with one hand and drilling with the other. Clamp is always safer though.
  #191
JohnEB's Avatar
Yeah I hear you.... The reason why I mentioned that is because I did a 3/8 npt. So I had to have it deep enough to tap it properly.
Old Nov 24, 2010 | 07:57 PM
  #192
tscompusa2's Avatar
my bad its 1/2 NPT lol. 5/8 would be insane
Old Nov 24, 2010 | 07:59 PM
  #193
JohnEB's Avatar
Old Nov 24, 2010 | 08:00 PM
  #194
JohnEB's Avatar
I was gonna say.... I was thinking you wouldn't have room...
Old Nov 24, 2010 | 08:01 PM
  #195
n2oiroc's Avatar
are you guys chiseling the baffles out then gluing them back in place or what?
