Turbo Spooling VERY slow.
Old Nov 21, 2010 | 10:26 PM
RSMike's Avatar
Originally Posted by sparky
What day and date?
monday 22nd Nov 2010, 7:25pm.
Old Nov 22, 2010 | 02:06 AM
tscompusa2's Avatar
whats your afr at spool?
Old Nov 22, 2010 | 06:15 AM
04EBevo's Avatar
I was re tuning it when I noticed this. Spool up afr are at 12.5 then down to 11.5 at peak boost and 11 at 7k. The hks cams are installed straight up. It is the old green and I believe it has a stock actuator, However it could be an 18psi actuator as I have never tried to take the mbc below 18.
Old Nov 22, 2010 | 06:25 AM
EvoPooPoo's Avatar
Did you install adjustable cam gears?
Old Nov 22, 2010 | 06:36 AM
04EBevo's Avatar
No I did not. These cams were the only mod on the car when I bought it.
Old Jan 18, 2011 | 09:14 PM
04EBevo's Avatar
Well, in all of this bad weather I finally found time to check the wga and sure enough there wasnt even a turn of preload on it. So i turned it to standard and turned the boost all the way down for safety. I get 24 psi of boost. So I am assuming I have an upgraded actuator from fp, is this a safe assumption?
On another note the turbo is spooling significantly faster and I have the typical green characteristics of 15 psi by 3250 and full boost at 4000.
Appauldd
Feb 15, 2017 07:05 AM
jnp1993
Jan 28, 2015 10:05 AM
alex the great
Mar 23, 2013 09:48 PM
evoboy2012
May 14, 2012 01:52 AM
mrb00st
May 5, 2008 07:56 PM
