Engine 8.5:1 compared to 9.0:1
Old Nov 25, 2010 | 01:21 PM
  #46
5LEEPERISAH23I's Avatar
So I should get a 10:1 with pump n meth that would be the best choice from what I read
Old Nov 25, 2010 | 01:59 PM
  #47
211Ratsbud's Avatar
You will choke your turbo out a touch sooner also. Meaning power will taper if you are already near the flow capacity of your hotside.
Boost threshold: the minimum RPM at which the engine is able to produce the engergy required of the compressor to make boost.
Spool: the ability of the turbo to recover and make boost, while the engine is in an RPM range which is sufficient for the process.
A high compression motor will decrease the boost threshold. yay or nay? and explain
A high compression motor will have some effect on spool. explain.
thanks
Old Nov 25, 2010 | 02:28 PM
  #48
wizzo 8's Avatar
Interesting read
Old Nov 25, 2010 | 11:27 PM
  #49
kpr's Avatar
kpr
Originally Posted by Mellon Tuning
I'm pretty happy with my 2.0 10:1 BR motor, 93 octane 600awhp at 30psi and the car feels much peppier at low boost, it's wicked on the street with 460tq. I had to back the timing off about 3* and 2psi vs my 9.5:1 motor to make the same power.
Chris
Is your new engine a 150mm rod or 156mm?
Old Nov 26, 2010 | 07:02 AM
  #50
Ted B's Avatar
That shouldn't happen, because increasing SCR doesn't increase VE.
Nay. A higher SCR will improve torque slightly, but torque isn't what spools the turbo.
It does, but the slightly increased thermal efficiency afforded by the higher SCR reduces exhaust gas energy, which tends to slow spool characteristics. This is offset to some degree by the slightly increased torque.
riceball777
Oct 26, 2016 06:26 AM
03evoslowtion
For Sale - Wheels / Tires
12
Jul 4, 2010 01:43 PM
ssteve
14
Mar 9, 2010 08:22 PM
SilverNine
Jun 28, 2006 04:09 PM
BALtown
Nov 27, 2003 07:06 PM
