Double Pumper Impressions and ?'s
Old Feb 8, 2011 | 07:10 PM
  #46
milford's Avatar
last weekend i ran my car 28 miles after the light came on and had no issues of cut out or hesitation at all...the last mile was up the hill to my house too. i was worried i was going to run out before i got home to fill up. i have a BR DP.
  #47
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by awdturbo8
Does Ted still modify the siphon tubes. I read a post about that a while back. I've always thought about doing that now that the car is down for the winter and I'm trying to fix all the bugs.
I tried to run both pumps together with my set up on the stock feed, and even with the drilled siphon, I was getting 60 psi at the fuel rail, so i just added a hobbs switch set to 9 psi.
Old Feb 8, 2011 | 07:11 PM
  #48
n2oiroc's Avatar
stock or aftermarket regulator?
Old Feb 8, 2011 | 07:12 PM
  #49
Veteran: Navy
stock
Old Feb 8, 2011 | 07:19 PM
  #50
n2oiroc's Avatar
stock
i'd hate to assume, but i would think an aftermarket regulator would have solved that issue. i guess that doesnt matter though, you solved it without spending a couple hundred bucks on a part that you didnt need in the end.
Old Feb 8, 2011 | 07:22 PM
  #51
SmurfZilla's Avatar
I'll double check the install when I start putting the car back together.
Old Feb 8, 2011 | 07:41 PM
  #52
R/TErnie's Avatar
I think I'm about ready to do a complete AN fuel system and stop dinking around.
Old Feb 8, 2011 | 08:03 PM
  #53
sparky's Avatar
I come from the Old World of TurboBuick GN's. Almost two decades ago, a Buick aftermarket supplier called Applied Technologies & Research(ATR) designed a double pumper fuel pump with dual WALBROS and they did it right with a machined, billet aluminum "Y" connector joining the two pumps.
I had one of these on my Buick and it was a really nice piece of kit. It was so much nicer than the current Evo double pumpers available which use two pieces of rubber hose instead of a machined, billet "Y" connector.
Maybe the Evo suppliers should take a retro-look at the groundbreaking, original 1990's ATR Double Pumper with a Billet "Y". I realize that I am talking about the previous century's technology. But, really wow two pumps connected by two chunks of flexible, rubber garden hose cut with a BoyScout knife, Duh?
jspecteggy
12
Feb 13, 2015 10:00 AM
chamelieon
18
Sep 14, 2014 02:38 PM
NOMIEZVR4
May 11, 2014 07:54 PM
5LEEPERISAH23I
May 13, 2012 09:48 PM
chkmgnt59
Jun 14, 2011 02:19 PM
