This looks wrong
Old Nov 30, 2010 | 06:47 AM
rartist's Avatar
This looks wrong
I just did a radiator swap, and I saw this when I had it taken apart. The rod on my VIII's waste gate actuator looks partly extended. I have a spare WG that someone gave me and that metal collar is flush with the base on that one. I was already racing the sun to get the new radiator in and didn't have time to mess with it, but it doesn't look right; it looks like the WG is partly open? I've never had that section of the motor taken apart before.
Old Nov 30, 2010 | 07:15 AM
YogSaahoth's Avatar
Veteran: Army
yea someone preloaded that wga pretty good. i usually set mine no larger than 1/4" from completely flush and have great boost response and holding on the oem wga.
If your car is driving well and u have no overboost or creep, u can just leave it probably.
If u want, just unhook the turnbuckle from the gate to make sure the actuator spring isnt defective or anything.
Then u could adjust the turnbuckle a half turn to a full turn clockwise to ease the preload a bit.
If when u go to remove the turnbuckle from the gate, there's no tension on the actuator arm and it doesnt immediately slide back toward the actuator head...you've got a busted wga.
Ive got an extra one for sale if it turns out to be broken.
Oh yea...could you possibly make the pic above a bit larger, I can't quite see it...
Old Nov 30, 2010 | 08:13 AM
evodood's Avatar
picture is sooooo big it's out of scale and hard to tell what if anything looks wrong.
if your not having issues with your turbo just leave it.
i would think that your decision to agdujst your WGA should come from turbo/engine performance and not be based on it's looks when you're changing your radiator.
Old Nov 30, 2010 | 05:42 PM
Craig King's Avatar
Maybe next time you could post a bigger picture so it's easier to see what we're looking at.
lillev23
For Sale - Part Outs
21
Mar 30, 2016 11:34 AM
black_beauty
Nov 17, 2014 07:10 PM
AWDTerror
Aug 8, 2009 05:41 PM
AfireINSIDE
Mar 23, 2007 04:50 PM
superalf574
Aug 23, 2006 01:44 PM
