drive belt help
Old Aug 16, 2006 | 08:44 PM
superalf574's Avatar
drive belt help
I was planning on changing my drive belts i.e powersteering ,alternator . since the 2002 's have two belts running off the crank pulley does any one know the part numbers for those two belts
Old Aug 16, 2006 | 08:53 PM
Walkingchaos's Avatar
just call a shop or dealer
Old Aug 16, 2006 | 09:24 PM
lilazn64's Avatar
I just changed mine. Got both Duralast belts from Autozone for about $28 for both. Install was pretty easy, minus the fact that I couldn't get my arm to fit well to adjust/loosen the accessory belt. Alternator belt was easy. All in all took me about an hour.
Old Aug 17, 2006 | 05:33 AM
crypto's Avatar
Former Vendor
how do you change the alternator and power steering belts. is there a how to anywhere?
cos if i can save money and do it myself i will.
Old Aug 17, 2006 | 07:09 AM
Lusion's Avatar
Theres 2 screws a 12 mm for the alternator belt, and a 14 mm for the PS/AC belt. Its a locking screw sorta, righty-tighty, lefty-loosy. You unscrew these screws loose enough for the belts to come off, then you swap your new belts. Just be careful with how loose/tight when you put the new belts on, it may cause squealing because of how loose/tight the belt is and you dont want the belt too loose because it might slip off. Try to find someone you know who can help. Ill try and get pics of the screws. Hope this helps.
Old Aug 17, 2006 | 07:22 AM
crypto's Avatar
Former Vendor
any pictures, just for reference. i have an idea where everything is, i just want to be sure before i attempt it.
Old Aug 17, 2006 | 10:01 AM
SLVROZ_03's Avatar
There should be something in the How-To's...
Old Aug 17, 2006 | 08:44 PM
mrtrunks's Avatar
I did mine about a month ago not hard tool about half hour give or take i'll post the napa part # after i fine them.
Old Aug 23, 2006 | 01:39 PM
sandman43103's Avatar
Changing Belts
Lusion-Have you had a chance to get the pictures of where those two bolts are located? I plan to change mine one of the next coming weekends, and any pics would be helpful. Thanks in advance.
Old Aug 23, 2006 | 01:44 PM
Lusion's Avatar
Oh, heh I forgot about this. Ill take some when I get home and post them up.
Huetsimus
Feb 17, 2017 08:23 AM
heavens turbo
Aug 3, 2016 10:02 AM
orion4096
35
Jan 25, 2016 03:37 PM
mcm308
20
Jul 21, 2011 09:55 PM
vtluu
16
Jan 8, 2011 07:57 AM
