cosworth head gasket over 40psi??
Old Dec 6, 2010 | 11:02 PM
RazorLab's Avatar
Originally Posted by davidbuschur
5 bar sensor, buried, stock head gasket. I have a hard time believing the hype that was written on the Cosworth gasket when the guy who wrote it can't keep a head gasket on the EVO he is involved with.
I'll take the Mitsubishi gasket.
ahhahaha. Indeed. Indeed.
Old Dec 7, 2010 | 04:07 AM
omniprobe's Avatar
I'm running L19's, not sure on the torque specs but I will ask the shop if you really want to know.
Old Dec 7, 2010 | 06:43 AM
David Buschur's Avatar
90 ft lbs is not enough torque. I'd take the L19 to at least 105 ft lbs if you are running high boost/cylinder pressures.
We've run the Cosworth gaskets in the past, I never found any benefit to them.
Old Dec 7, 2010 | 07:44 AM
njvlllrs's Avatar
thank you sir... yeah im boosting 40+ psi so i'll take them to 105ft lbs....
thanks everyone
Old Dec 7, 2010 | 06:59 PM
omniprobe's Avatar
What bores are the stock headgasket able to seal correctly?
Old Dec 7, 2010 | 07:25 PM
Andrewkbmx's Avatar
if your runnin oem headgaskets then i am too haha.
Old Dec 8, 2010 | 06:42 AM
Xenogenic's Avatar
ok what about using a headgasket on like a .40 over motor? cause the oem's barely fit on a .20 over.
Old Feb 16, 2014 | 06:25 PM
CodeOfDaStreets's Avatar
Does anyone know if the cosworth head gasket has built in firing rings like the feltpro pretorque hg??
Old Feb 19, 2014 | 02:12 PM
SkipDMan's Avatar
no input?, anyone?
05-EVO-GSR
Jan 17, 2017 02:51 PM
opie
For Sale - Cars For Sale
10
Dec 24, 2014 11:59 AM
b6429
Sep 17, 2013 03:15 AM
downforceinc
Evo 'For Sale' Engine Internals and Drivetrain
21
Jul 8, 2012 09:17 PM
