just installed cams and....
Old Dec 8, 2010 | 05:33 PM
AboodsEvo's Avatar
HKS 264/272 cams installed and I noticed after 4k rpm something sounds different. First I noticed some dash noise nothing serious, but then WOT to 4k then the engine sounds droney runs strong but sounds definetely different, first time I switch from stock cams. Has anyone experienced this after 3,800 or 4,000 rpms?? I dont know if its normal..
Old Dec 8, 2010 | 05:45 PM
Roadrunr's Avatar
Cam belt might be to tight. Did you follow the factory procedure ?
Don
Old Dec 8, 2010 | 06:02 PM
AboodsEvo's Avatar
Oh yeah, and I had my timing and balance belts, idlers, hydraulic tensioner replaced. I didnt see how tight the mechanic got them but he's done 1000's of timing belts so he knows his stuff. Thanks though il check it out
Old Dec 8, 2010 | 06:14 PM
Roadrunr's Avatar
Sounds like belt is tight and possibly the balance shaft timing is also incorrect.
Don
Old Dec 8, 2010 | 07:48 PM
AboodsEvo's Avatar
I dont hear any whining that indicates the belt might be tight. But I dont know whats going on, I just drove it for a bit and noticed alot of vibration 3500+ rpm from the engine bay even the dash and gear shifter. Im taking it back to the shop to check it out. Also, sometimes the rpm will jump to 1100 and stay for a few seconds does that mean the belt is too tight??
Old Dec 8, 2010 | 11:18 PM
ElectricBlueIX's Avatar
I can almost definitely say this was caused by your balance shafts being out of time....
I've seen this happen on DSM's and it sounds terrible. Get it checked out QUICK.
Old Dec 9, 2010 | 10:01 AM
MechTech's Avatar
Balance shafts out of time could def cause ur concern. Keep in mind with bigger cams the engine with have a bit of a different tone to it.
Old Dec 9, 2010 | 12:30 PM
Yeah that's true. I was concerned about the vibration he was talking about in the 3500-4000rpm range
Old Dec 9, 2010 | 01:02 PM
Ev0ikon's Avatar
Did you have it retuned after the cams change?
Old Dec 9, 2010 | 01:45 PM
widge's Avatar
I got a slight vibration after 4k after installing my S2's if i free rev it, but while driving its smooth up there,
I read somewhere you will know if the balance shaft is wrong as it shakes and vibrates even when in gear, so ive put mine down to extra vibrations from cams, ive been running the cams for about 6 months now with no dramas
Old Dec 9, 2010 | 02:07 PM
dan628's Avatar
if there is a problem, whoever tuned it should have noticed it, I would ask them.
Old Dec 9, 2010 | 04:29 PM
AboodsEvo's Avatar
Ok I'm at the shop my mech checked all timing marks and they were spot on! He said the only thing left that would cause the problem is the cam. I bought them used and they looked fine I don't know if cams were bad they cause vibration??? Can anyone confirm this? My only solution is putting the stock cams back on.
Old Dec 9, 2010 | 05:04 PM
AboodsEvo's Avatar
No i havent tuned it yet but I dont see how that has to do with vibration?
plus this sound isnt normal after 3500 rpm it sounds buzzy like a honda
Old Dec 9, 2010 | 05:56 PM
naplesevo's Avatar
this is why i am not a do it yourselfer
Old Dec 9, 2010 | 06:20 PM
AboodsEvo's Avatar
I didnt do it myself. I took it to a local shop hes done thousands of engine and timing jobs. I think its the balance shaft causin all this comotion im gonna check it out first thing tomorrow.
